Two Questions
Old Aug 7, 2019 | 10:59 AM
HRTKD's Avatar
HRTKD
Originally Posted by Straightgrain
If I found an alternative skid plate that was superior in protection to the OEM (thinking outside the box), that did not required drilling into the frame (coloring ouside the lines), I would do it.
I don't plan on skidding-over anything, but flying road debris can cause serious damage; that is what I would want protection from.
Chunks of tires, retreds, wire, metal, tree limbs, lumber, const. debris with nails, antlers, etc., bouncing up into a plastic fuel tank....sometimes, the debris cannot be avoided.
But drilling the frame to install anything (other than mounting a 30MM Vulcan) would be a big NO-NO.
Thanks, looking into after market.
Dom
My thinking is the same. No offroad worries, but debris could be an issue. I would expect the front axle to hit anything first, but after that it could fly up and hit just about anything under the frame.
If you find something, let us know.
