Sponsored by: Real Truck
Front tire wobble
Old Aug 4, 2019 | 01:32 PM
Shade guy's Avatar
Shade guy
Front tire wobble
2003 F350 2WD
I know this truck needs a alignment. It eats front tires
About a month ago it would start a death wobble after hitting a bump.
We had 2 new front tires put on it and it was fine.
One thing the tire guy did was used beads to balance them. He has recently lost his lease and is set up in a temp location without a balancer.
The tire guy is our friend and we always trade our labor for tires. So last week we stated getting a death wobble.
So I spent yesterday putting in new ball joints. My question is while I had the truck up off the front wheels I can grab the tires and it shifts side to side about a inch or so.
Is that normal?
On more thing is the power steering gear box has been leaking and has a leak at the pitman arm seal.
Old Aug 6, 2019 | 04:02 PM
aquaman's Avatar
aquaman
No good! It should not shift around. Find out what's loose. Is the entire linkage moving around, or only the wheel? Maybe it's the tie rod ends or something simple.
Old Aug 6, 2019 | 04:14 PM
don123's Avatar
don123
Originally Posted by Shade guy
2003 F350 2WD
Is that normal?
An inch of play is definitely not normal. Did you check all front end components?
Old Aug 6, 2019 | 06:34 PM
Shade guy's Avatar
Shade guy
It is the entire linkage. The pitman arm is moving
Old Aug 6, 2019 | 06:37 PM
Shade guy's Avatar
Shade guy
I guess I don't know how. All the little joints seem tight. They all move together.
Old Aug 6, 2019 | 07:22 PM
jav_eee's Avatar
jav_eee
Do you mean you can pull the tire out of the axle an inch or you can steer the wheel back and forth an inch?
Old Aug 7, 2019 | 07:48 AM
Shade guy's Avatar
Shade guy
I can steer the wheel back and forth an inch
Old Aug 7, 2019 | 09:24 PM
416bigbore's Avatar
416bigbore
Hello, Do you mean the steering wheel in the truck moves back and fourth an inch? If you are not sure as to the cause of your Death wobble ? I would take the truck into your nearest alignment shop and have them look at it and they will give you a free estimate as to what your problem is. This would be much safer and faster then you trying to guess whats causing all the play in your steering if your not sure how to check it correctly yourself. YouTube is also a great source for the DIY mechanics.
Old Aug 12, 2019 | 06:22 AM
SDSC4X4's Avatar
SDSC4X4
This is not normal. You can verify the tie rod ends and center link by jacking one side at a time and trying to replicate the movement turning the elevated wheel by hand while watching for play in those components. Or you can parallel park with one tire adjacent to a cub and have someone turn the steering wheel while you watch from below. It reads like your steering box is shot, and the extra play in the output shaft is allowing the seal to leak. Some seepage is normal over the years, but if it looks "wet" you have a problem.
Old Sep 8, 2019 | 12:31 PM
Shade guy's Avatar
Shade guy
After shooting the parts gun a few times I think I fixed it.
Axle pivot bushings. The problem was every time I jack it up I would put the jack stands on the axles.
I could not get that bearing to move with the trucks weight on it.
So new ball joints, drag link and tie rod ends did not help I also put in a new gear box mainly because it leaked.
Going to get it aligned tomorrow so maybe it will stop eating tires
Old Sep 9, 2019 | 09:02 AM
alloro's Avatar
alloro
Is the shock in good shape? A bad/blown shock will not dampen the spring bouncing action.
