Trying to figure out why my left rear wheel is so grabby and squeaks — all brake hw is new: new drums, new shoes, new wheel cylinders, brake lines, prop valve, master cylinder, etc.
did you use Grease on the dimples ?? and other pivot points ??
EDIT: and I'm sure you have lead and trailing shoes in correct places, I have to ask because I've seen the pro's put em on backwards
EDIT: I would wonder if the Parking brake cable maybe too tight or binding, might cause some grabbing, I doubt even if shoes were basackwards that it would cause your issue.
