Sponsored by: Kumho
DRW max tire size?
Old Aug 6, 2019 | 10:11 PM
alaskantinbender's Avatar
alaskantinbender
DRW max tire size?
I have a Class C E450 Thor 22B motorhome. We would like to put a slightly larger tire on it for better gravel road clearance.
Stock size is a 225/75R16 I have seen online that a 235/85R16 will fit the rear dual wheels. One shop I looked at in anchorage didn't want to try anything different from stock because of problems in the past. Anyone with real-world experience?
Thanx,
Jim
Old Aug 6, 2019 | 10:35 PM
85e150's Avatar
85e150
8.8" vs. 9.3" section width--so you lose 1/2" between the duals. Not sure how much space you have, but they must not touch.
29.3" vs. 31.7" diameter. 2.4"--that might be the concern, especially at full lock turning up front, or if you really compress the suspension.
Got these numbers from TireRack, for a Goodyear Trailrunner LT tire.
See if they will tell you what problem they are worried about--it might worry you too.....
Old Aug 6, 2019 | 11:32 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
another issue would be speedometer correction as this would affect shift points assuming it's an automatic.
EDIT: I say this as I don't know the vehicle year and if it has PSOM ability.
Old Aug 7, 2019 | 08:09 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
While we don’t know the offset or backspace figures for the wheels, I’d bet that half inch reduction in DRW spacing would be half of what is stock. Doing this to help drive gravel roads invites a rock getting lodged between dual sidewalls and rubbing holes in one or both tires. There’s no fixing sidewall damage. Stu
