Voltage
Old Aug 3, 2019 | 07:21 AM
green_95's Avatar
green_95
Voltage
Just wondering what kind of voltage every one is running while driving. I have a scan gauge II and mine runs anywhere from 13.5 to 13.9 while driving. Never hits 14. Is this normal or do I have a weak alternator?
Old Aug 3, 2019 | 07:55 AM
TooManyToys.'s Avatar
TooManyToys.
The PCM reporting of voltage out of the OBD2 can show a reading down to 0.5v from what it actually is at the battery or alternator. The best way to settle your concern is to use a voltmeter to check at the batteries, then compare that to what you are reading at the SG2 at the same time. The situation drove me nuts for a while.
Old Aug 3, 2019 | 02:28 PM
Euroman's Avatar
Euroman
And don't use one that plugs into the lighter socket - that can vary by a huge amount, depending on quality, other loads on the circuit, and temperature.
Old Aug 6, 2019 | 08:55 PM
Striderwv's Avatar
Striderwv
good info here on batteries and alternators
FICMRepair.com - FORD Powerstroke 6.0 FICM Repair, PHP Tuning and Truck Parts
1993 ford
Jun 16, 2017 04:40 PM
MoreBoostPlease
Oct 4, 2016 06:49 PM
Lliamspop
Mar 24, 2015 04:20 PM
Skattracker3
Mar 15, 2013 08:33 AM
Fluid Power
Jul 8, 2010 01:56 PM
