Speedometer Calibration Using Forscan
Old Apr 24, 2018 | 09:32 PM
GregA's Avatar
GregA
"Wine edition"? What I downloaded was from here:
Download FORScan
FORScan version 2.3.14 beta for Windows - free
Then activated Extended using the forum instructions.
What is your truck? I'm hearing various things about trucks with and without digital odometer. Mine is a '01 with analog (roller number) odometer.
Old Apr 25, 2018 | 06:18 AM
akcooper9's Avatar
akcooper9
Looks like you downloaded the correct version. Wonder why your view vs mine is different?
I know The Brad has an analog odometer vs mine being digital so that should not be the issue.
Did you try uninstalling and reinstalling? Ill send an email to Forscan and see if they have any suggestions.
Old Apr 25, 2018 | 07:17 AM
GregA's Avatar
GregA
I did. In fact, I uninstalled .14 and installed the February .13 to see if that made a difference; it did not. Then I re-downloaded and installed .14, same.
Edit: started a thread in config forum on ForScan, I'll see if I get a good response.
Old Apr 25, 2018 | 08:56 AM
akcooper9's Avatar
akcooper9
Sounds good, I sent them an email as well. Ill let you know.
Old Apr 26, 2018 | 12:40 PM
GregA's Avatar
GregA
FANTASTIC update. With the help of Aaron (akcooper9) and ForScan support, it turned out to be "An Excursion Thing". Aaron worked with them to obtain a program update, and it resolved it for me. I cannot believe how quickly they responded and turned this around, fewer than 24 hours; I will be donating to their cause and buying the Extended when that is available. I presume this change will be in the next beta update.
One side note: as expected, you cannot set revs/mi to less than 600 on our older trucks; anything less than that results in an error. However, as best I can tell there's nothing detrimental to setting the Ring Tone Size to a larger number to get effectively smaller revs/mi values (e.g., 600 revs/mi and 113 tone ring size = 594.7).
Thanks, Aaron!
Old Apr 26, 2018 | 01:05 PM
akcooper9's Avatar
akcooper9
Thanks, Aaron!
You are very welcome. Let us know how to 600 rev per mile and 113 tone ring works out on the drive home today!
Old Apr 26, 2018 | 07:38 PM
GregA's Avatar
GregA
Turns out I didn't need it; the number that got me spot-on with the Michelin 275/65-20s was 610!
Old Apr 26, 2018 | 08:53 PM
akcooper9's Avatar
akcooper9
Nicely done! I paid and downloaded forscan for my phone and tablet to help them out. They kick butt!
Old May 3, 2018 | 10:05 AM
GregA's Avatar
GregA
What hardware are you using for connecting? I'd like to use my iPad Mini, already have a center console mount for it.
Old May 3, 2018 | 10:08 AM
akcooper9's Avatar
akcooper9
I use this: OBDLink® MX Bluetooth | OBDLink® | OBD Solutions
Then either the laptop or android tablet/phone.
Old Oct 2, 2018 | 09:07 AM
sae1856's Avatar
sae1856
Trailering
Can you adjust the tire size specs on the android app or only on the windows version? Thanks!
Old Oct 2, 2018 | 09:08 AM
akcooper9's Avatar
akcooper9
I'm not sure but I believe only the windows version.
Old Mar 13, 2019 | 05:29 PM
  #28
00t444e's Avatar
00t444e
I tried this and I get a message saying " Writing block failed, Incomparable configuration"
Old Mar 13, 2019 | 05:34 PM
  #29
00t444e's Avatar
00t444e
It won't work for 590, 600 was the lowest I can get.
Old Mar 13, 2019 | 05:44 PM
  #30
akcooper9's Avatar
akcooper9
Good to know. You can adjust the tone ring value to correct for bigger then 600 rev per miles
