So, the floor in our camper in front of the sink dipped down for some reason so since the linoleum was torn anyway we tore out a section to look at the issue. All I can tell is the wood must just be getting weak. I will have to start cutting it away and see what I can do to replace that area and strengthen it up.
On a worse side we have a terribly rotten section in front of the rear door. That will take a little work to replace. Also need to figure out where the water is coming in. Ugh!
That sucks. Campers aren't easy to work on. How old is it? You reseal the roof periodically?
