Anyone use an Optima battery?
Old Jul 31, 2019 | 10:41 PM
6door74's Avatar
6door74
Good evening,
It's time to replace the battery in my 2006 E350 and I had a question. Does anyone use an Optima battery under the hood in the same spot as a factory battery? Is modification necessary? The website won't match me with a model. I have a powered subwoofer and TV monitor hooked up and I want a battery that can handle that. I was going to just get another motocraft battery but wondered about Optima because I still plan on getting a back up camera and possibly other accessories. I doubt it would ever be to the point where I would need multiple batteries though. What's the difference between red, yellow, and blue?
Thanks
Old Jul 31, 2019 | 11:03 PM
ford390gashog's Avatar
ford390gashog
So many better less gimmicky options available for AGM batteries these days. If you want value and AGM get the Everstart from Walmart or get the Northstar from batteries and bulbs. If you really want to step up get the Odyssey Extreme.
Old Jul 31, 2019 | 11:16 PM
6door74's Avatar
6door74
I was just at Wal-Mart staring at the everstart and telling myself don't be "cheap". Is the everstart a good value?
Old Jul 31, 2019 | 11:21 PM
Turningwrenches19's Avatar
Turningwrenches19
You want an Odyssey !! Speaking from experience.
Old Jul 31, 2019 | 11:23 PM
6door74's Avatar
6door74
Never heard of odyssey. Who sells it?
Old Jul 31, 2019 | 11:27 PM
6door74's Avatar
6door74
$300! Can't do that price right now. Found it online though. Amazon and from the manufacturer.
Old Aug 1, 2019 | 12:17 PM
ford390gashog
Yes for what it is and who makes it it's a very good value. It's not top of the line by but it's a good solid AGM platform. There is also the benefit the warranty is good and available at most walmart's. Be warned if you go with Odyssey they did do some renaming, you would be looking for the Extreme and not the performance as the performance is now the lower level. Still a good battery but its identical to the Northstar X2 which can be had for much cheaper locally at battery and bulbs for about 270.00.
Old Aug 1, 2019 | 07:00 PM
Im50fast's Avatar
Im50fast
Good evening,
Thanks
Red yellow blue is the different models for different uses.
are you aware that the battery doesn’t help you with power while the engine is running?
if you’re concerned with running all those accessories while the engine is running then you’ll need an upgraded alternator, not battery.
If your concern is running them with the engine off then yes, you’ll need an upgraded battery. I think you want ‘deep cycle’; with a high ‘reserve capacity’
Old Aug 1, 2019 | 07:02 PM
Im50fast's Avatar
Im50fast
And for the record; it seems foolish to think Wal-Mart sells as good a product as the same item from a high end manufacturer.
Old Aug 1, 2019 | 08:34 PM
6door74's Avatar
6door74
Notice I said a good value. I was careful in my wording. Of course I wouldn't think it's the same.
Old Aug 1, 2019 | 08:35 PM
6door74's Avatar
6door74
We like to go to the drive in theater. So it would be good to use the speakers and subwoofer in the van and be safe from the mosquitoes
Old Aug 1, 2019 | 09:39 PM
ford390gashog
Hopefully you weren't saying Optima was high end, it surely isn't. The Everstart AGM is made by East Penn also known as Deka in USA. It is the same battery sold under several names and the quality has proven to be good for the price. Same battery is sold as the Deka Intimidator, Napa AGM, Remy and Duracell AGM.The Optima batteries are a novelty gimmick at best, these batteries are made for the consumer and proudly made in Mexico by Johnson Controls. The Optima also doesn't come in standard size and requires adapters. Compare the Optima for weight and performance against any other comparable battery and you will see they weigh less, have lower reserve capacity.
Old Aug 2, 2019 | 01:57 AM
Scndsin's Avatar
Scndsin
Just changed out an Optima red top group 34 that's not supposed to fit my application.
Damn thing only lasted 13 years. Cable ends look brand new. Can't imagine what I was thinking when I bought it.
Those plastic wedge things that snap on in 2 seconds to keep it held down in a standard Ford battery tray are a joke.
Somehow it never moved a millimeter in all that time.
I really should have bought 2 or 3 regular batteries.
Old Aug 2, 2019 | 04:18 AM
JWA's Avatar
JWA
I love it ^^^^^!
I've been using the better or best quality NAPA battery for the past 10-12 years in different E-Series, have never had one fail on me during my own life expectancy---if I get a good solid 7 years out of one I'm fine. I certainly don't bash those who opt for something they feel is better by whatever metric they use to gauge quality or "value". I do watch my alternator's performance, almost never have a load on the battery when the engine's not running--maybe all that contributes to my "luck" with batteries?
I do see the Optima name mentioned in other forums, AGM is also bandied about by the mini-RV segment of van owners. There are lots of choices in both claimed quality and pricing---tough to know in advance what's going to be best until they're put into use and have some years on them.
Old Aug 2, 2019 | 04:43 AM
Im50fast's Avatar
Im50fast
That’s a lot of very specific info/claims. What’s your source?
I know there’s a Johnson Controls right here in Florida (Tampa) that makes car batteries. Seems odd that you claim Mexico.
For the record; if I find out Optima is made in Mexico (and there’s a compatible or better unit made in America) then I won’t buy it.
I’m tired of people fervently claiming “buy local!” But then shopping at Amazon, or national chains, etc. I mean hey, some things just aren’t feasible, but it’s appropriate to try.
All else aside, your claim that Optima batteries are a gimmick- that’s definitely not true.
