stalling out
Old Jul 31, 2019 | 12:53 PM
tmarxmiller's Avatar
tmarxmiller
stalling out
My 1988 F-250 with a 7.3 LD with ATS turbo, is running rough , bucking and kicking, and stalls out. Then it is hard to get started again. It appears as though it has a fuel problem, but I dont know if it is the mechanical pump on the engine or the fuel distribution block that is on the top from of the engine. The filter has been replaced, the fuel lines from the tank crossover valve and the valve have been replaced. I'm getting ready to replace the mechanical pump, and I'm hoping that is the problem. If it is the fuel distribution unit, anyone have any ideas for things to check there. I am very qualified for gas engines, but am a little out of my element with the diesal. All the info I can find is for power stroke diesels. any suggestions on where to find appropriate vids on the earlier models, like mine.
Thanks for the help and suggestions.
Old Jul 31, 2019 | 03:03 PM
Scott in TX's Avatar
Scott in TX
How long have you owned the truck?
how many miles are on it?
currently Does it ever run smoothly?
when was the last time it ran without a problem?
has it ever had the injector pump or injectors changed?
I think I would hook a diesel can up to the front of the truck to bypass everything to the injection pump and see if that helps, it's a cheap and easy test to trouble shoot what direction the problem is,
Old Jul 31, 2019 | 03:12 PM
rbfunk85's Avatar
rbfunk85
Very true. Then you would know if it is your hard fuel lines, o-rings on the ejectors or anything related to that area of the fuel system.
silentforever
Nov 22, 2011 06:53 PM
Devin JD
Nov 4, 2010 07:32 PM
geoffstowing
Oct 4, 2010 10:36 AM
a711112a
Aug 28, 2009 09:09 PM
Nxsov180db
Sep 26, 2006 07:52 PM
