2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
Replace 22"s with 20"s
Old Jul 30, 2019 | 10:11 PM
WW26Red's Avatar
WW26Red
Arrow Replace 22"s with 20"s
Final thoughts: I have the opportunity to swap the factory 22" rims and tires on my 2016 EL King Ranch for 20" rims with brand new tires. I've heard conflicting info back and forth on both sides of the camp, about the CCD being affected etc. Has anyone done this or swapped rims and run into issues? I would prefer the smoother ride of the smaller rims and larger tire sidewall, plus I just like the look of the 20" rims. Input is appreciated, I have to make a decision in the next couple of days and once deal is called off it is done. It is a Ford dealer making the swap so they will reprogram the pressure sensors, etc. Just need to know for sure if there is going to be an issue if a swap is made, because of it's made it's a done deal Thank you.
Old Jul 31, 2019 | 08:14 AM
dlcorbett's Avatar
dlcorbett
Just from tire maintenance and repair costs justify the switch to me. The ride should atleast be as good or slightly better with the 20s and should be better in bad weather as well. If the dealer is doing it at no costs and you like the wheels, get em.
Old Jul 31, 2019 | 09:51 AM
glockholiday's Avatar
glockholiday
Do it, shouldn't be any issues
WW26Red
Jul 10, 2019 10:12 PM
mlminor
Jul 4, 2009 03:24 PM
04SilverSCFX4
2004 - 2008 F150
Aug 3, 2004 09:14 PM
88grandmarquis
Feb 28, 2003 10:44 AM
