Door switch question-Answered
Old Jul 30, 2019 | 04:24 PM
RyanMac119's Avatar
RyanMac119
I have a switch that is malfunctioning, causing the interior lights and running board lights to stay on until the relay shuts them off. I’ve narrowed the issue down to the rear hatch glass. If I’m not mistaken, there are two switches on the glass? One on each side? If I disconnect, will the issue stop, or do I need to replace?
edit: I did try the WD-40 method.
Old Aug 1, 2019 | 03:54 PM
RyanMac119's Avatar
RyanMac119
So I finally had daylight after work to see what was going on.
i removed the interior trim pieces around the rear hatch glass to gain access to the door switch(es). There are two. One in each side. I unplugged them both and my issue was resolved. The running board lights and interior lights now switch off after about 30 seconds.
Old Aug 2, 2019 | 07:32 AM
Theboneskes's Avatar
Theboneskes
The only "issue" you will find, is that when you open the rear hatch glass and not another door, is the lights won't come on/stay on... But. If you open another door, problem solved!
Old Aug 2, 2019 | 09:29 AM
Stewart_H's Avatar
Stewart_H
Scooby snacks for thread closure!!
Stewart
2006fordf25060
Aug 21, 2017 08:26 PM
EXv10
May 4, 2010 10:34 PM
Kid Bronco
1978 - 1996 Big Bronco
Dec 22, 2006 09:17 PM
98expyinglendora
Jan 13, 2005 11:43 AM
Beaned
Aerostar
17
Feb 29, 2004 04:54 PM
