Looking for help deciding the VIN
I have a truck I found on my brothers property and I’m in the process of removing it from the woods the frame is still solid and axles but the rest isn’t, just looking for help figuring out what his tuck was and engine size as well as transmission type the dealers can’t seem to help me or larger truck shops that run old fords and Louisville’s. thanks the vin is attached in the pictures the tuck has been sitting in the ground since 1976
I have a truck I found on my brothers property and I’m in the process of removing it from the woods, the frame is still solid and axles but the rest isn’t.
Just looking for help figuring out what his truck was and engine size as well as transmission type.
The dealers can’t seem to help me or larger truck shops that run old fords and Louisville’s.
C = 330 2V Medium Duty FT engine.
C = Oakville Ontario Canada Truck Assembly Plant.
D09641 = 1968.
174" Wheelbase.
E = Light Blue.
F500, 15000 lbs. GVWR
4 81: 4 = Charcoal Black Crush Vinyl & Charcoal Black Ladder Pattern Vinyl // 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
62 = Timken model F106N Single Speed Rear Axle / 6.20-1 / 15,000 lbs Axle Capacity.
15,000 lbs. Gross Vehicle Weight Rating.
164 net HP @ 3,800 RPM
B37362:
B3 = FoMoCo of Canada Ltd. - Atlantic Ford Division, where the original selling dealer ordered the truck from.
7362 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
F-500
F50 = F500.
D09641 = 1968.
174" Wheelbase.
E = Light Blue.
B37362:
D09641 = 1968.
174" Wheelbase.
E = Light Blue.
B37362:
izaquad
Large Truck
02-06-2018 09:52 PM
Jeffrey Robertson
08-15-2017 01:07 PM
