I have the original bezel for my truck but no radio. I would like to install an am/fm back in the truck and not cut the bezel up. What ford radios will fit in the stock bezel ( mustang, Torino, falcon, or Lincoln) or any other out there with out going to after market?
Doing a quick check on his profile, it is listed as a '69. That opens to most any standard radio from back then. Yes, the '67 was a one year deal and the ***** were closer together and limits your radio choice.
The radio bezel is the same 1968/72 F100/750. The passenger car and Econoline radios probably will not fit into this bezel. I know the 1966/77 Bronco radio won't.
1971/72 F100/350's were available with an optional AM/FM, this is very hard to find today. Would likely find Amelia Earhart or Jimmy Hoffa before you found the radio.
