GT40 head help
Old Jul 27, 2019 | 08:21 PM
Deadsquiggles's Avatar
Deadsquiggles
GT40 head help
So I plan on building a new motor for my truck using 3 bar GT40 heads that I’ve had laying in the garage for a couple years (new seals but they might need to be replaced due to sitting?) and I have a couple questions.
First, I plan on replacing the valve springs to handle higher lift and I plan on using a set (https://www.alexsparts.com/sb-ford-g...ft-vsk7h48-13/) from Alex’s Parts that handle up to .550 lift without mods, but I’m not sure about the valve stem length differences it mentions.
Second, and I know it’s pretty beat to death, but how well would GT40 heads, a Comp Cams 35-349-8 and maybe shorty headers pair up with a Speed Density 302 in a ‘93 Bronco?
Old Jul 28, 2019 | 01:02 AM
Conanski's Avatar
Conanski
The exhaust valves on these and many other Ford heads have shorter stems than the intake valves and to account for this the factory exhaust springs are shorter so the same retainers can be used on all. These aftermarket springs are all the same height so to get them to work correctly(have the same closed seat pressure and spring rate) the exhaust retainers have to be different.. they will have a deeper dish.
That cam, heads, and exhaust will be too much for both the truck EFI control system and it's fuel delivery components, all together that combo will make well over 300hp which is more than the stock injectors can supply.
Old Jul 28, 2019 | 07:10 AM
Deadsquiggles
35-512-8 - Xtreme Energy? Computer Controlled Hydraulic Roller Camshafts (For 1992-02 Magnum Engines WITH 1.6:1 ROCKERS)
Would something like this work better with only .480” lift?
Old Jul 28, 2019 | 09:24 AM
Conanski's Avatar
Conanski
Cam lift isn't really what counts towards fueling requirements it's more about the total duration so yes this cam would be a better fit.
Old Jul 28, 2019 | 09:40 AM
Deadsquiggles
but It would give a good increase in power and torque without maxing out the injectors?
Old Jul 28, 2019 | 02:10 PM
Deadsquiggles
So after some research about casting numbers, I decided to look at the bottom of the heads and the casting is F3ZE-AA which combined with 1/2” head bolt holes indicates these they came off of a Lightening, correct?
Also, I’m attaching pictures of the rocker arm mounts and they look as though they’re already set up for screw-in stud mounts. Is this correct?
Old Jul 29, 2019 | 08:06 PM
baddad457's Avatar
baddad457
The valve stems are all the same length, the position of the lock grooves is different. If the stems were different lengths, the pushrods would have to be as well. The only SBF heads with shorter valve stems are in the E6SE heads.
Old Aug 12, 2019 | 05:30 PM
5851a's Avatar
5851a
That is just the regular bolt down rocker set up 5/16 threads I believe.
Old Aug 12, 2019 | 10:05 PM
baddad457's Avatar
baddad457
Correct.
Bobjoesun
Jan 30, 2012 07:10 PM
jaye
Sep 26, 2011 03:08 AM
sleep_deprived129
Mar 4, 2009 11:11 PM
66ford400
May 30, 2005 02:50 AM
Katmandu2
Jun 29, 2003 03:44 PM
