Transmission input shaft "failure"
Old Jul 26, 2019 | 12:22 PM
KingRanch16's Avatar
KingRanch16
Hello all –
I have a 2016 F-350 FX4 SRW King Ranch with ~ 88,000 miles on it. The truck is a daily driver and spends most of the time on highway. It has been used to tow light loads ~9 times in 3 years. These consisted of a 26’ boat 4 times, an 18’ dump trailer 2 times, a 17’ boat a total of 15 miles, and a 12’ U-Haul from AZ to KY. All of the loads are obviously WAY below what the vehicle is rated for. The only change from stock is the installation of 35 x 12.5 tires.
Last week while merging after exiting the highway there was a “bang” and the RPM’s shot up. I immediately let off the gas, coasted for a minute than tried again. Nothing but an RPM increase, nothing going to transmission. I coasted to a parking lot and called for a tow to the local dealership.
The next day I was informed that I had been “mislead” by my salesman in AZ when I purchased the truck who pointed to the warranty information manual where it said diesel engine warranty and said that since I have the diesel and it is a different powertrain that the powertrain is covered to 100,000 miles. Apparently only the diesel engine itself is covered to 100,000 and the transmission gets the same warranty as the one in the Festiva.
Today they called and informed me that the issue was caused due to an input shaft “failure” (read broke). The remedy was to replace the transmission at a cost of ~$7,000.
After hearing this I contacted Ford Customer Affairs because there is no way that an input shaft that is rated at 1,400 ft/lbs of input torque should have “failed” on a vehicle with the mileage and usage of mine. They promptly told me that it is outside warranty and that since they have not had this failure documented it couldn’t be a manufacturing defect. That seems counter intuitive based upon my engineering experience in both manufacturing and high end medical systems.
I guess my questions are these:
Has anyone heard of this issue happening?
Does anyone have any input as to possible causes (defective manufacturing aside)?
Has anyone replaced the transmission on one of these?
If so how difficult was it, do they have any instructions, were there any special tools involved?
I have extensive experience pulling and building engines, in just about anything you can name so I have the ability to do it myself. I just have no experience working on diesels, and I have never replaced a transmission on one of these.
Thoughts and input are appreciated.
Old Jul 26, 2019 | 04:24 PM
HRTKD's Avatar
HRTKD
I did a Google search and came up empty on input shaft failures for the 6R140 transmission.
The transmission is indeed not covered by the 5 year/100,000 mile warranty that the diesel engine is covered under.
I can't help with the other questions other than to say I pulled a transmission from a '91 Ranger by myself and it sucked. I had a guy rebuild it that had extensive experience with GM transmissions. Mine never worked right again and leaked oil. Choose carefully who fixes your transmission.
Had I kept my Nissan Titan, it was going to be sent to Level 10 Transmissions to get a bulletproof transmission. Their website covers several Ford transmissions but not the 6R140. At the very least, a call to them might get you an expert opinion.
Old Jul 26, 2019 | 04:43 PM
Desert Don's Avatar
Desert Don
Originally Posted by KingRanch16
Hello all –
So, did they drop the transmission to come up with that conclusion? If not, how did they come up with that? Myself, I would suspect something in the transfer case ( if 4WD) let go ( like the chain ).
Old Jul 26, 2019 | 05:42 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
An independent shop could fix or replace that transmission for half of what the dealer wants.
I've obviously not seen this particular shaft. It could have had an inclusion that produced a weak spot. It could have had a machining error, but that rarely happens to one piece, it would tend to happen to a series of pieces.
Old Jul 26, 2019 | 05:45 PM
RedRage's Avatar
RedRage
Mmmmmmm
I've never heard of such a thing. Wrong diagnosis. Breaking an input shaft? I doubt it.
Probably the same Ford tech who told me the 6.7's are great motors except for the weak timing chains. True story.
Old Jul 26, 2019 | 05:47 PM
ford390gashog's Avatar
ford390gashog
My old 2012 had a broken input shaft. It was a clean break at the splines. Got really lucky and was able to just swap the shaft and the torque converter. This is a rare failure and isn't common. I will also say you are probably better off going to a well regarded transmission shop. A used 6R140 is actually very cheap with low mileage if you want to source one used.
Old Jul 26, 2019 | 05:55 PM
KingRanch16
Thanks for the responses.
I also scoured the net and couldn’t find any issues similar to mine with this transmission.
I am trying to find out how they diagnosed the issue. When the problem happened and I was in the lot awaiting tow I tried the transmission in D,M,2,1 and R. I also cycled 2H, 4H, and 4L. None of these had any change in problem.
Old Jul 26, 2019 | 09:58 PM
cangim's Avatar
cangim
Interested in outcome
Old Jul 26, 2019 | 10:16 PM
HRTKD's Avatar
HRTKD
I've heard of more transfer case problems than transmission problems. Since the transfer case is bolted to the transmission, there's no way to observe if the transmission is sending output to the transmission. If the chain is broken then none of the modes (2Hi, 4Hi, 4Lo) is going to work.
There may be some diagnostics the dealership can look at to see that none of the engine RPM is making it to the transmission. That may be what led them to say the input shaft failed.
Old Jul 27, 2019 | 07:33 AM
Mark Kovalsky
Sure there is. There are speed sensors that will show if the shafts are turning or not. They could also check for pressure at the test port to see if the pump is turning.
Old Jul 27, 2019 | 08:21 AM
HRTKD's Avatar
HRTKD
Come on Mark. Surely you understood that I meant there was no way to look for a shaft that was turning. My next paragraph specifically mentioned other diagnostics.
Old Jul 27, 2019 | 11:20 AM
Mark Kovalsky
To look at the shaft, no. To know if the shaft is turning or not, sure you can. Can you only diagnose things that you can see? There are much better ways.
Old Jul 29, 2019 | 12:27 PM
KingRanch16
I spoke to the dealership today. They said that they transmission failed data logging (showed no rotation on input shaft despite crank RPM in first and second gear). So there is no rotation in the transmission which is what I figured, so my question is what is likelihood of the input shaft braking under less than designed usage? Would it be more possible that the torque converter broke and is not engaging? To me that would also give the same result. I obviously am not transmission guy, my experience stops at the flex plate.
I have heard that the transmission would need to be programmed after install so it isn't really possible to change it myself, is that accurate?
Old Jul 29, 2019 | 12:34 PM
Mark Kovalsky
Either the torque converter or the input shaft has failed. It's one of those two. I can't tell which one until the trans is out and then it will be obvious. In the end, does it matter if it's the torque converter or the input shaft? Replace the broken part and move on. Or replace the whole trans.
I don't know the answer to that.
Old Jul 29, 2019 | 02:36 PM
djousma's Avatar
djousma
deleted.......
