2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Towing Package
Old Jul 25, 2019 | 09:53 AM
SharpTJ's Avatar
SharpTJ
Towing Package
I am thinking about buying a large bumper pull camper. It has dry weight of about 6100 lbs. I am trying to figure out if I have the HD towing package. I have the 7 pin connecter and what looks to be a bracket for a missing brake controller.
The front end has been rebuilt using F150 parts, but there does seem. To is an axillary cooloer in front of the radiator.
VIN if it helps... I tried the window sticker app but it doesn't work.
1FMJK1K59BEF29154
Old Jul 26, 2019 | 08:46 AM
meborder's Avatar
meborder
HD towing package comes with auxiliary transmission cooler, electric brake controller, and 7pin wiring harness along with a limited slip differential.
From your description it sounds like you do.
Old Jul 26, 2019 | 09:45 AM
SharpTJ's Avatar
SharpTJ
Is it an external controller or built in?
Old Jul 26, 2019 | 12:48 PM
meborder's Avatar
meborder
Should be built in directly below the AC controlls right above the console if it is a factory controller.
Old Jul 26, 2019 | 01:25 PM
SharpTJ's Avatar
SharpTJ
No factory controller then... That mean not HD towing package?
Old Jul 26, 2019 | 02:56 PM
meborder's Avatar
meborder
Post up a pic of your trans coooler and wiring.your axle code would help tell as well.
Old Jul 26, 2019 | 03:55 PM
SharpTJ's Avatar
SharpTJ
Where do I get the axle code? According to the VIN, It has 3.73 ratio if that helps... Pic of the radiator and additional cooler probably would help as the front clip was rebuilt with a F-150 clip.
Old Jul 26, 2019 | 04:01 PM
meborder's Avatar
meborder
Axle code is on the door tag where you find the vin.
Old Jul 26, 2019 | 04:39 PM
SharpTJ's Avatar
SharpTJ
Old Jul 27, 2019 | 08:37 AM
meborder's Avatar
meborder
16 = 3.73 open
i
Old Jul 27, 2019 | 09:44 AM
SharpTJ's Avatar
SharpTJ
16 = 3.73 open
i
So no HD Towing?
Old Jul 27, 2019 | 10:27 AM
meborder's Avatar
meborder
If they used an f150 front clip the radiator and auxiliary transmission cooler would have been a direct fit, so as you say that’s not much help.
Without the factory brake controller and with an open differential, it points more toward “no” than “yes”
now you you have to decide whether that means anything to you or not.
Old Jul 31, 2019 | 03:41 PM
PLCguy's Avatar
PLCguy
SharpTJ:
I don't think you have it. I looked at the VIN report link for your vehicle. I have a 2011 Navi with the tow package. I ran my VIN through the same decoder, your VIN report would have an option entry like mine below.
Do you have the air shocks in the rear? It looks like you also get the load leveling air shocks with the Tow Package.
crosseye
All Things Towing
Nov 5, 2019 04:21 AM
ckal704
Aug 27, 2014 07:29 PM
calidogj14
2009 - 2014 F150
Mar 13, 2010 06:42 AM
y2klarry
All Things Towing
Dec 10, 2004 08:19 PM
janstang351
2004 - 2008 F150
28
Sep 10, 2004 11:19 PM
