CONSIDERING A PROPRIDE HITCH
Old Jul 24, 2019 | 04:06 PM
smokekiki's Avatar
smokekiki
I have a 34' Primetime Lacrosse that I pull with my Excursion. It weighs 9800 loaded . I am using an Equalizer 12000lb hitch. I have not had any problems with the hitch once set up. I have first dibs on a pretty cheap propride.. It should have the bearings replaced. The real issue is my driveway. It is really steep. I pull up the drive, and have room up top to turn around. At the top, if I leave the foot on the jack, it will scrape just a little. I also remove the weight bars before turning up the drive.
Anyone that has a Propride, would it handle the turn, and head up the steep drive? It appears to hang pretty low. Any idea how low they hang below the tongue? The ball receiver on the trailer is just a tad higher than the trailer frame. It does sit 23" from the ground to the inside of the ball receiver.
Thanks!
Old Jul 25, 2019 | 04:33 PM
jasoncw's Avatar
jasoncw
Here's a pic I found on FB. It sounds like you need to remove the bars to have room, then I don't think it would be a wise choice. It is a bit time consuming to pull the bars, as they are held in with little pucks that can be difficult to fish out. Although, I don't really have a lot of experience removing mine, as they always stay attached.
Old Jul 28, 2019 | 09:23 AM
smokekiki's Avatar
smokekiki
Thanks,
That picture helps a lot.
Roush F-250
May 20, 2019 01:23 PM
jstange2
6.7L Power Stroke Diesel
13
Mar 21, 2012 11:25 AM
wagoncrazy
All Things Towing
Oct 6, 2008 11:35 AM
Fair 96
All Things Towing
Feb 24, 2005 06:13 PM
Ratsmoker
All Things Towing
Feb 1, 2004 11:27 PM
