99 exp question
Old Jul 23, 2019 | 04:02 AM
Texasgirl2019's Avatar
Texasgirl2019
99 exp question
ok so long story short. I was in a huge storm, pulled off to a friend's property. Anyway i had ran up on a huge rock. My tranny pan got punctured. Didn't drive it , move it, etc after. I replaced the pan and filter. I drove the truck home no problems until i tried to turn it off. The truck wouldn't go into park. Started looking and noticed linkage cable was kinked. So i replaced. Truck still wouldn't go into proper gear, replaced neutral safety switch. Now the truck goes in gear, but will not move unless you rev up for awhile, once it starts to move it feels like back breaks are engaged. So now i have no idea what to check for next or where to start. Please help truck has been down for three months.
Its a 99 exp 5.4 triton
Old Jul 23, 2019 | 09:42 AM
Hamfisted's Avatar
Hamfisted
You've checked the fluid level with the engine running right ? Is the fluid still bright red in color ? No burnt smell ? Any transmission DTC codes on a scanner? Wheels spin freely if you do them by hand ?
Old Jul 23, 2019 | 01:39 PM
Texasgirl2019
Yes i checked the fluid, bright red in color, truck isnt throwing any codes, yes wheels spin freely
Old Jul 24, 2019 | 10:21 AM
alloro's Avatar
alloro
Check the two cooling lines to make sure they didn't get damaged. Other than that it sounds like it's sucking air, meaning either the fluid level is still low, or the new filter isn't installed properly.
Old Jul 24, 2019 | 10:48 AM
Texasgirl2019
Could it be some pressure sensor or something like that. Its got plenty of fluid. If i check the coolant lines is there some way to check from there to see if there is any pressure? Also i read somewhere that the lines have to be vacuumed? Is that correct because i dont think it is. Thanks for all the responses.
Old Jul 24, 2019 | 07:57 PM
Spaznaut's Avatar
Spaznaut
Did you check the fluid level with the engine running and in park? When you hit the pan did it do any damage to the filter mounting that would cause a new filter to not seal up and suck air? How much damage (deep of a dent) was there to the pan? Not sure if these have the 2 different filters like some f150s but maybe they put in the wrong filter.
BEEFKING69
1997 - 2003 F150
Feb 13, 2018 08:52 AM
bj3hedrick
Aug 12, 2015 09:02 AM
andydunks
Feb 6, 2015 04:12 PM
metalbender1
23
Feb 28, 2011 07:55 AM
nancyan
Mar 13, 2003 11:53 AM
