Piston Slap (knock)
Old Oct 6, 2003 | 09:45 AM
bronco351's Avatar
bronco351
Piston Slap (knock)
I have a 1998 Ford Expediton with the 5.4L Engine. Last week my truck developed a very loud knock, only when the engine is cold. I understand this is a common problem with expeditons. Is ford doing something to correct the problem, like replacing engines? If not, what can I do to make this noise less noticeable. maybe, use a different oil. ANy suggestions you guys can give me will definetly help. By the way, my truck only has 75,000 miles.
Thanks a Bunch!!!
Old Oct 25, 2003 | 07:26 PM
FoMoCo136's Avatar
FoMoCo136
Mine has 120,000 and has this noise when it is cold. I think it might be the cam tensioners. I have a friend with an Explorer and his noise was the tensioners. Just a thought,,,,,
Old Oct 26, 2003 | 12:43 AM
bronco351's Avatar
bronco351
Well, let me update you all on my situation. Since I didn't get any responses, I decided to go ahead and try to fix it myself.
I switched my truck over from Castrol GTX 10W-30 to Mobil-1 5W30 Full-synthetic. After I did that the knocking has completely dissappeard. So I hope this helps someone with my same problem!!
TCAS007
29
Jul 13, 2017 09:28 AM
Ford-Muscle
13
Feb 13, 2016 06:09 PM
2009Exp
Jul 26, 2011 10:54 AM
cccullen
Jul 16, 2009 06:58 PM
shadowcatcher
Electrical Systems/Wiring
Sep 29, 2003 05:04 PM
