Electrical Problems
Old Oct 6, 2003 | 09:12 AM
JohnBaker's Avatar
JohnBaker
Electrical Problems
I have 93 F-150 and the turn signals, cruise control do not work and the ABS light is on. What can be the problem
Old Oct 6, 2003 | 11:06 AM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
Most likely your clockspring is bad. That would cause your symptoms. I bet your horn don't work niether huh?
Old Oct 6, 2003 | 11:12 AM
JohnBaker's Avatar
JohnBaker
What is a *****pring and where is it located
Old Oct 7, 2003 | 10:17 AM
gatesj's Avatar
gatesj
It's a long section of wire wound like a clockspring that goes from your steering column to your steering wheel. It coils and uncoils as you turn the wheel. It's what connects the airbag and horn switch in the wheel to the rest of the truck.
