Washer pump question
Old Jul 21, 2019 | 07:39 PM
fordboy67's Avatar
fordboy67
I am in process of replacing rear wiper motor. It is out waiting for warranty replacement and I tried the front washer and it didn't work. Is this because the rear wiper motor is disconnected? Or is this an un related issue? Tried a search but I'm technically hadicapped
Old Jul 21, 2019 | 09:29 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Wiper motor is not wired to the pump at all. They don't talk...It is a long distance relationship.
For the pump, it spins one way to squirt the front, and spins the other way to squirt the back. You simply reverse the polarity of the voltage to make it happen. This is done inside the multi-function switch.
Old Jul 24, 2019 | 05:43 PM
fordboy67's Avatar
fordboy67
Just an update. The front washer WILL NOT work while the rear wiper motor is disconnected. Once I put in the new rear wiper motor the front washer resumed working. So they are somehow connected.
jberylecrider
Nov 14, 2019 12:39 PM
uncleben03
Aug 17, 2015 01:15 AM
KeystoneHomeOK
Jun 23, 2014 08:33 PM
chicagodragon
Aug 22, 2010 10:22 PM
