Rear windshield wiper issue
Old Jun 15, 2014 | 07:57 AM
KeystoneHomeOK's Avatar
KeystoneHomeOK
I tried it search for this but the search function seems to have a mind of its own. I just bought my '98 Expy XLT 4X4 and am in the process of making sure everything is working. I noticed when I bought it that the rear wiper didn't work but that is an easy fix. However, it rained a couple of days ago and without thinking I hit the wiper switch and it worked! I replaced the wiper blade and now I can't get it to come back on. Do you guys think this is a possible connector issue on the wiper motor or just time to get a new motor? Sometimes I can hear the motor try to engage and sometimes I hear nothing at all.
Thanks for your time, it's nice to be back here after a 2 year absence.
Old Jun 15, 2014 | 10:39 AM
alloro's Avatar
alloro
Try this repair: https://www.ford-trucks.com/forums/5...wiper-fix.html
Old Jun 15, 2014 | 04:27 PM
KeystoneHomeOK
Well, umm, it's not broken.
I can't believe it, but the rear wiper will not activate until the front wiper is on. None of the other vehicles I have had with rear wipers have been like that.
I feel like such a newb! LOL!
Old Jun 15, 2014 | 08:20 PM
alloro's Avatar
alloro
It's not supposed to be like that. Perhaps the switch is bad or a secondary power wire is broken.
Old Jun 16, 2014 | 06:32 AM
KeystoneHomeOK
That makes me feel a little better. As long as I can get them to come on when it's raining I can use it like it is til it quits completely. I'll just live with the gremlins as they are for now.
Old Jun 18, 2014 | 01:19 PM
mediaman67's Avatar
mediaman67
I have a simple problem - can someone link me to how to adjust the rear arm? right now my 2003 Gator has it sitting off the window, and it should be straight across.
Thanks
Old Jun 18, 2014 | 02:40 PM
alwaysfords41's Avatar
alwaysfords41
I haven't had to do it, but there is a cap over the hinge area that pops off and under that is a nut. I'd assume that nut is holding the arm on a spline so if you loosen it you can move it one spline over.
Old Jun 19, 2014 | 10:35 AM
r2millers's Avatar
r2millers
Similar to the link alloro sent you, I have someone turn the wipers on inside and I hold the wiper assembly and push at the same time.
That bushing will stick and hold the shaft from moving. Once you break the resistance as noted, mine works again until long periods of it sitting still.
The get a bigger hammer approach, but it works.
Old Jun 19, 2014 | 10:52 AM
KeystoneHomeOK
Thanks
I had that with my 2001 after I replaced the wiper motor. Turn the rear wiper off, remove the cover at the hinge, take off the bolt, slide the arm off of the splines and put it back aligned properly. If it keeps happening the splines could be worn from having a loose nut.
My wife says my truck always has trouble because of the loose nut behind the wheel......
Old Jun 19, 2014 | 12:29 PM
alwaysfords41
[quote=KeystoneHomeOK;14442595]remove the cover at the hinge, take off the bolt, slide the arm off of the splines and put it back aligned properly.quote]
Seems vaguely familiar for some reason.....
Old Jun 20, 2014 | 06:46 AM
KeystoneHomeOK
[QUOTE=alwaysfords41;14442838]
LOL! Sorry about that! I had run out of coffee and forgot my most important rule about posting in forums....make sure coffee capacity is topped off before posting.
Old Jun 21, 2014 | 05:33 PM
KeystoneHomeOK
Well, driving home I ended up driving about 10 miles in the rain and I could not get the rear wiper to work at all.
Old Jun 23, 2014 | 08:33 PM
KeystoneHomeOK
Finally got a chance to look closely at my rear wiper and discovered a couple of things:
1) The relays are working
2) The motor isn't
3) Wiper arm splines are worn smooth
4) It's about what I expected
jberylecrider
Nov 14, 2019 12:39 PM
Paul69104
May 17, 2007 11:33 AM
hap
May 17, 2004 05:39 AM
hokiebob
Apr 11, 2003 08:20 PM
