Sponsored by: Innova
vibrating roof
Old Oct 6, 2003 | 08:40 AM
jesse460's Avatar
jesse460
vibrating roof
if i take down the headliner and put dynamat between the liner and and the roof will it stop the vibrating?
Old Oct 6, 2003 | 09:33 AM
PrPlayboy's Avatar
PrPlayboy
It will help. Vibration dampening adds mass to metal. You sure thats all thats vibrating? What kind of car/truck do u have?
Old Oct 6, 2003 | 10:17 AM
jesse460's Avatar
jesse460
no its not the only thing it is just the worst. it also rattles the passenger side door but i can adjust the door to tighten it up. the truck is a 95 f150 ext cab. you cant hear the noises in the truck only outside with the windows up thanks, jesse
Old Oct 6, 2003 | 01:16 PM
PrPlayboy's Avatar
PrPlayboy
Do searches on boards for sound/vibration dampening and there will be tons of info on the subject. If your roof is that bad i would definately dampen it. I use the stuff from Mcmaster.com. Trucks are easy to do and you usually get good results because the metal is thick to begin with.
Old Oct 6, 2003 | 11:48 PM
michaeld6638's Avatar
michaeld6638
or you could just turn the bass down a notch
