6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Crank no start
Old Jul 21, 2019 | 10:32 AM
ThomasB_6.4's Avatar
ThomasB_6.4
Crank no start
Got an 09 6.4 250 less than 100k. With All the necessary deletes and h&s tune. Was cruising at 35 she started to boog down. I pulled over and it stalled out. Would only crank no start. Towed it home did an advanced scan hoping for any easy fix. Not so much. Lpfp seems to be running fine. Changed the fuel filters found a tiny amout of metallic shavings in the upper fillter housing. Computer got less that 5000psi to the fuel rail. But the scan showed many components lost contact with ecm/pcm A. Part of me feels the alternator may have been going bad and possibly fried the pcm with the help of the tuner. So Im torn between a pcm and a hpfp. Any help or experience on this issue would be appreciated..
Old Jul 29, 2019 | 07:38 PM
Fefanatic's Avatar
Fefanatic
Have you cleared the codes and did they return? Were you monitoring fuel pressure during cranking? FWIW, metal shavings in the upper filter is a bad sign. Did you see any rust in the bottom of the filter housing?
kaharvey88
Apr 27, 2018 11:13 AM
ididntdoit89
Feb 26, 2018 08:40 AM
Lhornung
Mar 1, 2017 10:07 PM
lindboep
Jul 28, 2014 02:29 PM
1Fastboy
Sep 24, 2012 01:14 PM
