1968 Door Latch
Old Jul 20, 2019 | 02:13 PM
idhiboy's Avatar
idhiboy
1968 Door Latch
My Drivers side door latch is worn down. I have release mechanism out and there are grooves in mechanism worn, such that when I try to open from inside, there is too much play and doesn't trigger latch
Is there ANY ford (merc, broncho, mustang) that had similar door latch and door release set up? When I look at LMC, then dont have the mechanism for a F100-250 door latch mechanism, They do have the inner release, but that is not the worn part
I guess my alterative is too pull out the rod and fabricate a new connecting rod that is shorter....
Ideas? Resources??
thanks
Old Jul 20, 2019 | 04:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1968 door latch
Is there ANY ford (merc, broncho, mustang) that had similar door latch and door release set up? No
When I look at LMC, then dont have the mechanism for a F100-250 door latch mechanism, They do have the inner release, but that is not the worn part.
C8TZ-8121813-A .. Left Door Latch / Obsolete
1968/72 F100/750 (F100/250/350/500/600/700/750) //1967 F100/750 is not the same!
No Ford dealer or obsolete parts vendor has any, none on ebay, not reproduced AFAIK
Old Jul 21, 2019 | 05:13 AM
Coastal68's Avatar
Coastal68
I had a broken return spring for the 'jaws' on my driver's side latch. looked for months on ebay. Put out wanted ads. Nuthin.
I had to rob a spring from a passenger's side latch to fix it.Two weeks later a pair came up for sale on ebay. Figures. They were sold within days.
For some strange reason, these aren't reproduced. Maybe we should petition Dennis Carpenter. A least they should repro the driver's latch.
Old Jul 21, 2019 | 05:25 AM
mrpotatohead's Avatar
mrpotatohead
I'm sure I can get you a door latch. P.M. me if you're interested.
Old Jul 21, 2019 | 11:56 AM
Lrrr-RulerOfOmicronP's Avatar
My interior handle was wore down on mine. I bought a new one from rockauto that looked exactly the same. They did send me the wrong part the first time but the second part was spot on.
Door interior handle
scf100
Dec 17, 2017 02:07 PM
Unimog005
Mar 20, 2017 09:39 AM
Pappys53
WTB - Parts & other
Sep 1, 2011 07:12 AM
RJP66F100
Jun 8, 2010 11:49 PM
FAST-FORD
Mar 25, 2008 07:43 PM
