AC issues 2007 E350 Van 5.4L
Old Jul 18, 2019 | 01:18 PM
Getherdone's Avatar
Getherdone
Hello all,
My first forum I have every sign up for, see how it works, so bare with me.
This van has been setting for 6 years at the farm. I thought I would get it home and get it running for my son. We have cleaned her up and serviced everything. But we can not get the ac compressor to come on. We have power the low pressure (purple wire)and have jumped it but no clutch engagement, check for power to the compressor clutch wire and no power to the compressor clutch. There is Freon pressure in the system we checked that first thing. The fuse in the engine compartment for the "AC" is good. I have read about a ac relay, but not clear where it is to check the relay.
If I can answer any questions to help with this, let me know.
Any suggestions would be very helpful.
Thanks!
Old Jul 18, 2019 | 10:19 PM
F350 1990's Avatar
F350 1990
As a rule of thumb, sitting that long would require a complete flush, evac of the system, likely new orings throughout, new accum, vac pull down and new refrigerant...................here's a quick troubleshooting guide to get started:
Low Pressure Low
High Pressure Low >>>>
Low refrigerant Charge
Low side normal
High Side Low>>>>
High Side Restriction
Low side normal/high
High Side Normal/High >>>>
System Overcharged
Low side high
High Side high >>>>
Moisture in the system
Low side Low
High Side Normal>>>>
Faulty Cycling Switch
System will not operate
Stuck open>>>> Cycling Switch
Low side high
High Side high >>>>
Inoperative cooling fan, blocked Condenser
Old Jul 19, 2019 | 04:32 AM
JWA's Avatar
JWA
How did you test the van's current refrigerant charge?
Your best bet is to post this same question in the A/C sub-forum here--include your year and model in the body of your message as that's very helpful.
You might also obtain an EVTM or book of schematics that shows not only the wiring & circuits it'll help locate parts associated with any one system. This would be useful for the A/C issues as well as just about every other electrical situation you may encounter.
HTH
Old Jul 19, 2019 | 03:17 PM
Getherdone's Avatar
Getherdone
HTH
Check the charge with 134 gauges. I will move A/C, thanks
Michael Ward
Jun 1, 2017 10:06 AM
Laggy
Jun 1, 2017 10:01 AM
Muffinman
Aerostar
May 21, 2013 07:14 PM
PAf250
43
Oct 1, 2011 05:54 PM
dino360
Sep 5, 2004 12:07 PM
