Sponsored by: Real Truck
Replace oil pan 7.3
Old Jul 17, 2019 | 09:35 PM
Jimv8's Avatar
Jimv8
Replace oil pan 7.3
So I bought this neat old truck knowing it needed an oil pan and it was factored into the price. I did my homework and bought the Moroso gasket and a new pan. I got the truck raised and ready to go. Of all the methods I’ve read up on I’m going with raising the cab and then the engine and
Ready to go
Getting it in the air.
seems the least likely to cause other damage to parts. So I’ll keep my progress posted and plan on starting tomorrow so wish me luck and if you have any last minute advice or insights please don’t hesitate to chime in
Old Aug 1, 2019 | 08:35 PM
Jimv8's Avatar
Jimv8
Yes it is possible to replace the oil pan on a 2002 f250 7.3 without pulling the engine and on the degree of difficulty scale of 1 to 10 it is an 11. Of course knowing then what I know now would move the scale to about 8.
as described in the guys YouTube vid the cab has to be loosened and raised as does the engine. It’s IMPORTANT to do it in stages though. Lift the body two inches then lift the engine two inches, rinse repeat until it’s a the needed height. DO NOT REMOVE the rear transmission nuts. Yes by all means loosen them so they’re holding by a half dozen threads. If you remove the nuts the engine will be free to move forward and side to side and the pan ain’t never coming out. It’s also a really good idea to remove the front sway bar completely so the lifting doesn’t crush the transmission cooler line as well as the bottom rad hoses. Obviously I didn’t remove the sway bar and I have some repairs to make. Because I removed the transmission mount nuts I used a little bottle jack between the starter and the cross member to push the damn thing back far enough for the pan to drop.
So I finally got the new pan ‘made in China, (what isn’t these days), now doing it over I’d really carefully check it against the old before trying to fit it, that would have told me I’d have to grind a bit more relief around the filter housing. The Moroso rubber gasket is a thing of beauty but the f*#%@ing thing flops all over and it damn near impossible to keep it in place for the mount. So I came up with an idea, which was to tie string through the holes of the gasket and pan at the corners. Now if I had todo it over I’d use slip knots to make getting the string out a lot easier.
The whole process has taken about a week and a half and thankfully the weather was great.
This how high the cab has to lift
Old Aug 1, 2019 | 10:07 PM
phillips91's Avatar
phillips91
I’ve never changed one on a super duty, and after seeing this I don’t think I will lol.
Old Aug 3, 2019 | 07:19 AM
Jimv8's Avatar
Jimv8
I added more paint to the new pan before fitting it. I got a paint similar to POR15 did 2 coats and top coated that with Tremclad gloss black. The pan will now outlast the truck.
This shows the battered the old pan and I didn’t want to do that to the new pan so I built a cradle to put the weight against the flanges.
Salty Dog
Jul 23, 2017 01:53 AM
Tugly
Aug 15, 2016 11:09 AM
Dorsai
Mar 12, 2013 10:48 PM
tjthegreat
Sep 23, 2009 08:33 PM
boo-yaa138
23
Jul 6, 2009 02:52 PM
