2008 Expedition XLT AC issue.
Going to try and break this down. My AC blows cool while driving on the highway. When I say cool it was 90deg this morning and it was around 74deg coming out of the front vents on the highway doing 70mph. The back AC vents never did cool down. When stopped only warm air. When it reaches over 101deg no cool air at all on the highway it stays warm. I am guessing the pressure has gotten too high to cycle the compressor?
I am lost as to where to start. I don't have unlimited funds as I am out due to back surgery a month ago and can't return to work for another 6wks. 🙄
I appreciate any assistance.
Tom
Tom
Then it wasn't doing anything. The compressor simply isn't doing any work although to your eye it appears to be running.
When the clutch is off, the pressure should equalize to the static pressure determined by the underhood temperature. 130 psi equates to around 100F.
When the compressor clutch engages and the center shaft actually rotates (CHECK IT) and the compressor operates, the low side gauge should drop and the high side should rise as the compressor creates a pressure differential. It is possible for the clutch to engage but the clutch has failed causing the shaft to remain stationary. You have to make complete observations once you know what to look for.
If there is no differential created, it's usually due to either an internally sheared compressor shaft or the internal valves have failed.
pretty much, if the gauges are set up right AND the compressor is working (Center part turning), the internals of the compressor is shot. you will have to replace, at the least, the compressor, expansion tube and accumulator. I would also, with the age of the vehicle, the condenser as well just to remove that variable as well.
rock auto is your friend.
D
D
that's static pressure: same between low and high side. When the compressor is running it should around what my chart I am attaching says
