Fan malfunction
You can also use an ohm meter to test the various switch contacts. The resistance should be the same from the ground pin through each of the other pins. The fact that you have high speed indicates the ground is OK.
By | 2026-06-12 11:01:55
By | 2026-06-09 11:10:08
By | 2026-06-09 10:53:36
By | 2026-06-08 18:50:34
By | 2026-06-05 12:58:01
By | 2026-06-03 09:51:16
By | 2026-06-03 15:43:58
By | 2026-06-03 11:38:36
By | 2026-05-27 16:24:34
By | 2026-05-27 16:17:28
