E99 a/c questions
Old 07-14-2019, 07:31 PM
udsuth78's Avatar
udsuth78
udsuth78 is online now
Received 1,385 Likes on 1,034 Posts
I checked the blend door and the recirculate door and both are working like they should. So now I'm down to the compressor being weak, low charge, or clutch being completely shot.
Old 07-14-2019, 08:51 PM
fordboy2's Avatar
fordboy2
fordboy2 is offline
Following along as I have this same issue with my 99, slow speed(below 30) or idle it’ll freeze yo right out of the truck but anything above that your lucky if you get comfortable less alone cool.
Old 07-15-2019, 03:44 PM
udsuth78's Avatar
udsuth78
I bypassed the heater core this afternoon. It dropped the temp at the vent about 10 degrees. I'm still thinking I need to evacuate the system and give it a fresh charge. This truck was in the shop over the winter getting a motor swap and I can't be sure they did it when they recharged it.
Old 07-15-2019, 03:52 PM
udsuth78's Avatar
udsuth78
I saw last night on Harbor Freights website that they have a rinky-dink little vacuum pump for under twenty bucks. Looks like a POS but the reviews are pretty good. Then I'd know for sure there wasn't any air or moisture in the system and that it had the right amount of refrigerant
Old 07-15-2019, 05:11 PM
FordTruckNoob's Avatar
FordTruckNoob
FordTruckNoob is online now
Identifies as He/Him/Noob
Received 3,041 Likes on 2,006 Posts
As long as it gets the system down to 100 microns or better then you're good to go. The expensive ones are expensive because they need to be used more than once a month.
I use one of these: http://www.jbind.com/products/produc...px?SKU=DV-200N
Old 07-16-2019, 04:10 PM
udsuth78's Avatar
udsuth78
I evacuated the system pulled a vacuum of -25 for 45 minutes then held it for 5 minutes and refilled the system. Now I'm getting 55 to 60 degrees at idle and 45 running down the highway. I think that fixed it. Nipples are rock hard now
Old 07-16-2019, 04:12 PM
FordTruckNoob
Lol. Good job with the nipples.
iblackford
Escape & Escape Hybrid
06-23-2016 07:17 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
01-03-2016 08:48 AM
JonathanN
1999 to 2016 Super Duty
05-24-2011 01:34 PM
marcusaharold
06-24-2010 03:34 PM
cyclenut80
06-22-2009 07:58 AM
Quick Reply: E99 a/c questions
