transmission ??
Old Oct 5, 2003 | 09:53 PM
2low4you's Avatar
2low4you
transmission ??
i was out beating up the ford today i go in to this deep mud hole and all of a sudden clutch goes to the floor and get this real bad shakeing its like its stuck in neutrel finnaly get the peddal back and now its locked up i have a 89 f150 5spd just put the clutch in thursday did something in the tranny break or do u think its the clutch
Old Oct 8, 2003 | 05:42 PM
AEQUITAS333's Avatar
AEQUITAS333
Does your trans have a hydralic clutch? If so check the resivour, it's not that expensive and easy to swap out two bolts and a pin. It is located right next to the brake fluid.
