Distributor oil pump shaft?
Old Jul 11, 2019 | 03:14 PM
Roadoilers's Avatar
Roadoilers
Hi all, I'm getting closer to sorting this truck out, replaced just about everything now.
I had a lot of sideways movement with the rotor arm on the dizzy shaft so I ordered a recon dizzy.
Rotor arm fitted the new dizzy fine due to a little metal spring clip on the new dizzy shaft. Kinda like a shim.
Went to swap out the dizzy and when I withdrew my old dizzy I've got the oil pump shaft connected to it.
The dizzy and oil pump rod are actually drilled and pinned together, the new dizzy has not got a pilot hole drilled so I didn't bother fitting it I just took the spring clip off the recon unit and fitted it to my old dizzy and no more rotor arm movement.
I still want to swap over the distributors as the Devon one is a lot cleaner and just wondered if this is common.
Old Jul 11, 2019 | 03:50 PM
charliemccraney's Avatar
charliemccraney
Which engine?
Definitely incorrect if it is a Y-Block. The distributor and oil pump drive shaft are not held together in any way.
Old Jul 11, 2019 | 08:27 PM
hiball3985's Avatar
hiball3985
Originally Posted by charliemccraney
Which engine?
He has a 223 I6, and the shaft should be attached to the dizzy. I've seen pictures on EvilBay showing the dizzy without but I think they are just generic photos. If it doesn't have a shaft attached I would return it.
Old Jul 20, 2019 | 09:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C2AZ-6A618-A .. Distributor Drive Shaft - Includes 354494-S pin / Obsolete ~ 100+ available NOS
1957/61 223 // 1962 223 before serial number 323,001 // 1961 262, 1962 262 before serial number 320,001.
C2AZ-6A618-B .. Distributor Drive Shaft - 3.92" long - includes retainer / Obsolete ~ 40+ available NOS
1962 223/262 from serial number 320,001 // 1963/64 223/262.
annaleigh
Apr 23, 2015 03:14 PM
b4hntn
1978 - 1996 Big Bronco
Sep 1, 2007 08:59 AM
stuffman
20
Mar 10, 2004 02:39 AM
Polkat
Nov 19, 2002 10:47 PM
oft
Mar 17, 2001 04:21 PM
