Fox Fail
Old Jul 11, 2019 | 12:46 PM
shizzu's Avatar
shizzu
Fox Fail
Well, that didn't take long(12k miles), one of my Fox shocks failed, appears to be from a chip on the shaft. Any suggestions on how to prevent this in the future? This shock is on the front side of the rear axle, the one on the rear appears fine.
Old Jul 11, 2019 | 01:03 PM
skanj0's Avatar
skanj0
Yep. Despite what the shock vendors say, install a boot on the shock. I had the same problem with my ICON 2.5” shock in that same location. Cut a 1/4” hole near the bottom of the boot, on the rearward side to let any water or crud drain out.
Or install what is called a ‘Roost Shield’, which is a plastic shield to guard the shaft from rock impacts.
Old Jul 11, 2019 | 01:39 PM
DSLTRK60's Avatar
DSLTRK60
Fox makes a set of protectors for the 2.0 shocks. They call them roost shields and are cheap at around 33 bucks.
Silicone boots with bottom cut off will work also but look hokey imo.
Old Jul 11, 2019 | 08:32 PM
cain0725's Avatar
cain0725
ride
do they even ride better? worth swapping out factory
Old Jul 11, 2019 | 10:44 PM
honda250xtitan's Avatar
honda250xtitan
A blown out monotube IFP shock rides better than the brand new stock crap.
Old Jul 12, 2019 | 01:27 AM
Chaserev800kid's Avatar
Chaserev800kid
Yes unfortunately the fox 2.0s are prone to failure very easy. The shafts are way to soft and ding up easily. The fox 2.0s use just one o-ring to seal the shaft unlike a packing stack like more high dollar shocks. I’ve rebuilt all 4 of my fox 2.0 remote res that came with my carli kit multiple times. The one plus is that a rebuild kit is dirt cheap and they're easy to rebuild. I have Kings in route as we speak.
Old Jul 12, 2019 | 01:51 AM
willynilly's Avatar
willynilly
a precision shaft like shocks or dirt bike suspension, has to have some form of protection , mainly on the front side where debris impact happens, its just common sense
Old Jul 12, 2019 | 05:38 AM
BillyE's Avatar
BillyE
If the shaft gets dinged, a rebuild kit isn’t going to do much for you, is it?
Old Jul 12, 2019 | 08:10 AM
honda250xtitan
depending on how bad, he could sand it down to remove any burr's but yea a new shaft would be ideal, i doubt they're very pricey.
Dont ding your shaft, friends
waiting for moderation...lol
Old Jul 12, 2019 | 04:06 PM
GABAR's Avatar
GABAR
Dinging ones shaft can be a painful and expensive repair. Lol
Dr G
16
Jan 22, 2020 02:11 PM
adam2017
May 1, 2017 09:28 AM
GoldCo
Feb 26, 2017 07:37 AM
VH_Girl
Feb 20, 2013 01:28 PM
gimphunter
Feb 14, 2006 08:46 AM
