Please Help
Old Jul 10, 2019 | 01:11 PM
Matthew Carswell's Avatar
Matthew Carswell
Please Help
So the company I work for owns a 2014 F250 with the 6.7. An employee of ours was towing a covered trailer and two motorcycles, no more than 3000lbs. The trucks RPMs would all drop and the engine would go into "heavy duty mode" like it was trying to avoid overheating or something. Any idea what could cause this? We took it to two separate dealerships and they both told us the truck is totally fine. There have been no codes or anything like that. I don't want to keep spending money to have somebody tell me "It's fine".
Old Jul 10, 2019 | 01:27 PM
djousma's Avatar
djousma
Sounds like goes into limp mode? Or was it just the fan coming on hard? How far do the RPM's drop? Do you lose speed? If you mash the pedal, does it go? You dont say, but did you go to Ford Dealerships? Seems like it should throw a code if there were a problem.
Old Jul 10, 2019 | 10:47 PM
The Bone's Avatar
The Bone
Are you using tow haul mode?
Old Jul 11, 2019 | 03:44 AM
2011350diesel's Avatar
2011350diesel
I've been having this problem. 2011 350. All the gauges are normal, transmission temp is fine, rpms are fine, not using anymore fuel than normal.The fan kicks on and the truck sounds like it's working overtime, really hard.No codes.And the kicker is, that it will do it always when it's hot out or sunny. When it's raining no-problems.The truck doesn't want to shift. Have had it at 2 different dealers and the first time they did a program update last sept. and this worked through out the winter.This past June started doing it again.Took it to another dealer and no codes, couldn't find anything.They performed another update and this lasted about 2-3 days.
Soo,I'm thinking either a bad clutch fan, a bad transmission temp sensor or the PCM. Something is telling the PCM to go into safety mode. Dunno, very frustrating.
Old Aug 6, 2019 | 03:01 AM
2011350diesel
Update on the problem that was having. Ended up being the fan clutch.
Old Aug 6, 2019 | 10:32 PM
The Bone's Avatar
The Bone
Not to bad Glad you got it figured out
JR58
6.4L Power Stroke Diesel
Apr 30, 2016 11:00 AM
tracyclifton
Jun 7, 2015 09:50 AM
AZ Elk Hunter
Jun 2, 2012 01:07 PM
bigred66
Apr 25, 2012 04:50 PM
Minnesota Sun Bird
Nov 17, 2006 09:42 PM
