1994 F150 4x4 leaking diff front diff fluid
Old Apr 28, 2001 | 08:35 PM
skywalker7918's Avatar
skywalker7918
Hi folks. I'm new here. I have a 1994 F150 4x4 w/a 351. It's pretty sound, but right now the front 44 is leaking at the diff on the passenger side. It's not bad, but I'm trying to sell it, and it looks bad to any non-mechanically inclined person.
Anyone know how to fix this? Or how much a shop may charge?
Thanks
Old Apr 28, 2001 | 11:06 PM
PAUL_2's Avatar
PAUL_2
Sounds like the axle seal is leaking , remove the axle & the old seal & replace it with a new seal .
Old Apr 29, 2001 | 01:01 AM
skywalker7918
That sounds nice and simple, but I've never pulled a shaft from my TTB before. Don't I need that special socket to get to the shaft? And then from there do I need a seal puller? I don't mean to sound like a newbie, but I've never worked on that TTB before, aside from installing the lift. It doesn't look very user-servicable. Thanks for the help
Old Apr 29, 2001 | 12:42 PM
PAUL_2's Avatar
PAUL_2
Its not really as bad as it looks . The first thing you need to do is get a repair manual to help you out with the details & torque specs . Youll need the socket to remove the axle nut & a sealer puller , both of those are relatively inexpensive . If you like detail with a repair manual Id recommend the Helm manuals . The only other snag you may run into is the spindle bolts , they are fine thread & they have to be very clean because of the high torque values needed to tighten them , if the nuts or bolts have any brake dust or dirt on them when you go to torque them they will strip . Once you get the right side brake , spindle & all those parts out of the way , you will be able to slide the axle out , pop the old seal out & tap in the new one .
Old Apr 30, 2001 | 04:07 AM
hotrodford_88's Avatar
hotrodford_88
eduhat
Dec 22, 2015 06:29 PM
lakewood
Dec 26, 2013 10:57 AM
mikren
1997 - 2003 F150
Sep 15, 2009 08:09 AM
joewaldner
Offroad & 4x4
Sep 14, 2008 10:24 PM
joewaldner
Offroad & 4x4
35
Jun 18, 2008 09:35 AM
