2015 Ford F150 5.0 4x4. I have been having an intermittent issue with lights popping on but its getting worse first i will have warning about abs off, hill start assist fault, traction control etc. It will just as fast disappear. i will get the orange wrench on the display that will go away once i shut down for a while. this morning when i started i now had steering errors and had no power steering for a while. it went away on its own and drives fine now. I hooked it to a scanner and it have several codes for loss on communication between the following: instrument panel, ecm/pcm a, body control module, transfer case module, steering column control, and invalid data. This has to be a plug or something. any one have any ideas where i can check or maybe something they have seen?
Have you checked your battery? These trucks can exhibit some strange behavior if the battery is going away.
I was going to start looking at that. I have heavy AFM lights and accessories. and i have done everything with 125% wire size and ran all wires correctly. There is a much bigger battery in it than originally came with the truck.
To be honest, the only way you’ll truly find out what’s causing these problems and throwing the codes, which are stored in the system regardless if they go away or not, is by taking it into your Ford dealer of choice or any shop that has the proper equipment.
The scanner you have will not tell you the full story of what’s going on.
I agree but you never know who may give a hint of a similar story. I can guarantee any non dealership shop has a scanner like mine. I usually get the newest snap on model and update it every six months. The only info i do not have is the subsequent codes causes and they erroneous codes triggered. .
Brought it to the FORD dealer. They were able to pin point it to the GEM module. Its the little black back that has the OBDII plug molded in. They swapped it, programmed it and said everything was talking properly again. about a week later same symptoms started. Only this time more frequent. almost every 4 ish days now.
Electrical problems and pinpointing the cause can be a PITA.
Sorry to hear that you’re still having issues and hopefully when you take it back to the dealer, they’ll be able to get it right.
Hey you ever figured this problem out? I've been having the time of my life trying to get my f-150 fx4 2010 back on the road and now i'm thinking it's the ABS module - the DTCs read "lost communication to " every module on the hs-can. The truck starts every time and sounds good, but stalls right away. It shows a wrench on the dash and says check brake system when it's started. But falls off and stalls right away as if the fuel was out..
This type of error needs real troubleshooting. A module may be bad or the CAN wiring may be damaged or connector corroded. You need a scan tool and ideally an oscilloscope to look at the network signals. Dealerships are notorious for swapping modules without fixing the problem.
Watch some South Main Auto YouTube videos. He repairs several Fords with network errors. You will see what types of checks you can do to hopefully find the problem. His customers frequently have broken or corroded connections due to rust from the road salts. You will have to go through the numerous video titles to find one that may apply to your situation.
Thanks for feeling my plight.. My entire truck harness looks like this.
If any one could possibly spot any corrosion or burnt or chewed or broken wires i would live them forever.
From the rear passenger tail light to the junction box I've opened up the entire harness, all my wires & connectors look as if they just came out the factory.
My fuel tank is on the floor, I've removed the timing belt cover to inspect..
I even got a new bcm & here's a whole thread on the F-150 forums about what else I've done:
https://www.f150forum.com/f38/crank-no-start-start-but-dies-immediately-not-fuel-pump-not-fpdm-not-fuse-576612/?utm_source=share-link&utm_medium=button&utm_campaign=share&utm_cont ent=post
You don't lack initiative, but you need information and a plan. Find or buy a set of wiring diagrams. Carefully map out the separate CAN networks. HS CAN is typically for critical functions like engine, brakes and safety. MS CAN is for lights, audio, climate etc. See if you can find a correlation between the comm faults and the separate networks. Then troubleshoot that network using an O-scope, measuring termination resistance etc. I'm no expert but I would watch instructional videos and read as much as possible. Isolate sub systems if possible. A faulty minor module may be affecting the network....who knows?
But I would waste money on my own diagnostic tools before I gave the dealership another dime. Maybe a local independent shop will be more helpful but they need to be good at these types of problems.
Why did you undo your whole loom? - Personally I would take it to an auto electrical place. We have a chain of shops called AES "Auto Electrical Services" around my area. Before you start unlooming things I would have tested the resistances of the wires to see if any are clearly compromised. You can cross reference the circuits with the diagrams from alldata. The way your trying to diagnose is like looking for a needle in a haystack and now any auto electrical mechanic you take it to is going to decline the work or at least I would.
I would put your truck together. Spit shine her up and take her down to carmax. If you have a back up truck then take her to the shop and have a professional diagnoses completed which on something like this takes a real pro and takes some time.
What's a minor module?
And that's exactly where I'm at - I've had technician come with IDS software and the last one said it's between the accelerator pedal and the junction box. So i opened the harness hoping i would find something like in this video @7:20 mark
It was my last hope of finding something bad. Now I'm at the ABS module and thinking of pulling a main harness from a junkyard truck but i can't find a 4x4 super crew cab nearby.
