I have an exhaust leak in the connection between the exhaust pipe and passenger side exhaust manifold. I was told there is no gasket, so how is it fixed? It is something in the connection...
Have you investigated the leak? You should recheck all bolts. If that doesnt work, something has probably warped or has broken. What does the actual meeting point look like, two flanges bolted together?
