Which oil
Old Jun 30, 2019 | 10:46 AM
green_95's Avatar
green_95
Which oil
I know this question could bring on 4 pages worth of responses with each one being different lol, I have used the search button and read up on google but I'm still co fused on 15w40 or 5w40. My 6.0 is stock with 100k miles. I have always used 15w40 in my 7.3 and never had a gave it another thought. But with this 6.0 I am reading conflicting opinions on whether or not I should use 15w40 or not. I do know I want use rotella just not sure if I should use the T6 or not. I dont pull anything and live in east tn where our winters are not all that cold. We may get a handful of single digit nights and just a little more teens. But on average I'd say our nightly lows are in the upper 20's to low 30's with a few real cold spells in between. I dont want to be switching back and forth for winter and summer, I want a year round oil. But I want what's gonna protect the engine.
Old Jun 30, 2019 | 10:49 AM
seville009's Avatar
seville009
The oil fill cap usually has the recommended specs stamped on it.
Manual should list the recommended specs too.
Old Jun 30, 2019 | 11:19 AM
diesel_dan's Avatar
diesel_dan
I think you're cold enough in winter to just go 5W 40 year-round. Lots of folks in warm climates run that weight as well...
Old Jun 30, 2019 | 11:57 AM
Ford.Dude's Avatar
Ford.Dude
I think this is one of those things that you'll have to decide for yourself. A month ago I was researching the same thing. For over 2 years I've ran T4 but I have always added archoil yo each of my oil changes. Blackstone has an issue with archoil additive. It's hard to tell if coolant is present in an oil sample. Oil additives have similar properties as coolant. This last oil change I went with T6 full synthetic. I need to check for oil loss due to burning it. PO said it seemed to burn oil when synthetic was used. But of course I have to see for myself.
The only difference I see is yes with T6 I do hear a smoother engine. The injector clatter is smoother sounding. I was worried about leaks popping up but no drips yet. I've only put about 200 miles on it since the change so I still have a ways to go before I could give my personal opinion.
I don't think it matters what you use as long as it's ford approved.
Old Jun 30, 2019 | 12:15 PM
AK4x4's Avatar
AK4x4
I run Motorcraft SAE 5W-40 Full Synthetic Diesel Motor Oil in my '05 6.0. engine runs good, no problems. Good luck, Russ
Old Jul 1, 2019 | 10:31 AM
High_HP's Avatar
High_HP
Latest 6.0 manual revision recommends 15w-40 over 5w-40 for towing/severe duty....so I use 15w-40. No injector issues etc after 180k miles.
Old Jul 1, 2019 | 02:22 PM
tfunk88's Avatar
tfunk88
I run full synthetic 5w-40 year round. My truck runs much better with it in both the heat AND the cold.
Remember, 5w-40 does NOT mean that it is a lighter weight oil than 15w-40. It is a more stable oil in terms of viscosity. In the cold it doesn’t thicken up as much as the 15w-40 does.
Old Jul 4, 2019 | 06:50 AM
carcus's Avatar
carcus
5w-40 full synthetic in my 2006, never had a issue with it
Old Jul 4, 2019 | 07:11 AM
bismic's Avatar
bismic
I think that we all decided in the early years of the 6.0L, that Ford's oil recommendations stemmed from the fact that AT THAT TIME, Ford did not sell a 5W40 oil!
I also think that the later model year injectors were less prone to stiction so they can better withstand 15W40 being used in the winter. Clearly there are numerous people that don't have stiction issues w/ 15W40, but there is no doubt that more people experience stiction issues w/ 15W40 oil than the 5W40 users .... especially in cold climates.
Old Jul 4, 2019 | 07:55 AM
green_95's Avatar
green_95
I'm going to use rotella t6 once I get this dang oil leak fixed.
juvat97
Apr 16, 2011 06:48 PM
scott4952
Apr 15, 2010 11:12 AM
6litrefan
Mar 14, 2009 08:11 PM
Trailblazed
Dec 28, 2007 04:53 PM
super duty 2880
Nov 20, 2007 02:24 PM
