ZF-5 Leaking
Old Jun 29, 2019 | 10:28 AM
redbayredneck's Avatar
redbayredneck
ZF-5 Leaking
As I mentioned in my other thread, I just recently put a newly rebuilt transmission in my truck. The shop took 7 weeks to build this transmission despite quoting me a 2 week turn around.
The transmission is doing great, shifts fine and drives wonderfully.
But, and there is always a but, I have a transmission fluid leak coming from the shifter. I spoke with a local, trusted diesel mechanic about it, and he advised me that it is probably coming from the plate on top of the transmission that is held on by 4 Allen-head screws. He advised just to add a little RTV to the gasket and see if that helped.
I removed the plate as directed, and found that there was no gasket there at all. the builder put a small amount of RTV and hoped for the best I guess. I cleaned all the old RTV off, and applied a better coating off oil resistant RTV in hopes of it fixing the issue.
I'm getting less fluid, but it still leaks. The thing is, it kind of looks like the fluid is coming out of the top of the inner shifter boot. Should I try buying a gasket to see if that further stems the flow of fluid, or is there a possibility that the fluid is coming out of the boot itself? Its a new boot and doesn't have any holes that I can find.
Thanks in advance for any and all help.
Taking it back to the builder is not really a preferred choice if I can fix it easily myself. They're over and hour from my house and I'd like to not pull the transmission again.
Old Jun 29, 2019 | 02:07 PM
z31freakify's Avatar
z31freakify
Check to see ig the vent tube aint clogged or bent.
Old Jun 29, 2019 | 04:55 PM
redbayredneck
Haven't been able to find a vent tube on it.
Old Jun 30, 2019 | 08:17 PM
ridemx129's Avatar
ridemx129
I didn’t see a vent tube on the trans, there was I next to the electrical connection on the drivers side of the transfer case.
Old Jun 30, 2019 | 09:43 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Lack of gasket would make me wonder about the quality of your rebuild. Hope you did not pay much.
Mine weeps some from that silly rubber boot up top. I think I put five quarts in the thing.
I recall it having a metal vent when I built mine.
Old Jul 1, 2019 | 12:19 AM
redbayredneck
The transmission itself seems to be operating fine and I have a decent warranty on it. It was supposedly dyno tested before they delivered it.
The shifter wasn't part of the rebuild, they just took mine off the old transmission and put it on the new one. They did replace the rubber boot at no charge, because my old one was torn and they took 7 weeks on a two week rebuild.
Old Jul 1, 2019 | 01:18 PM
Hit Man X's Avatar
Hit Man X
Question
So they put your shifter on another trans? Why the hell would it take them nearly two months when they did not even build your trans it sounds like.
That boot is maybe a $10 part retail, but they left the gasket off which is ODD.
Who did the work or did they just buy it from some wholesale trans place?
Old Jul 1, 2019 | 01:34 PM
redbayredneck
No, they built a new transmission for me. My old one cracked the casing somewhat horrendously. It was a complete build of a transmission using an empty case. That being said, instead of sourcing a new shifter, they used the one that was on my old transmission. I agree that them not using a gasket is odd, I also agree that 2 months was an excessive wait time. But I paid up front, and they extended my warranty due to the extremely long build time.
The shop was Man-trans in Tallahassee, Florida. I think they're main issue is that they over-sell their workforce; They take on more work than they can handle. But the transmission is driving fine and I have no complaints about the quality of the build so far.
They were the cheapest by about $400 within a 2 hour drive, and they picked up my old transmission and delivered the new one at no additional cost to me.
tfontaine1
Nov 5, 2017 05:30 AM
kjjr20
Feb 24, 2014 08:21 AM
Eicca
Jul 25, 2011 02:25 PM
f100kid1936
Oct 23, 2007 12:20 PM
parkjam
Mar 8, 2003 09:11 PM
