3 + 3 = 9 . . right?
Old Oct 5, 2003 | 11:38 AM
ctfuzzy's Avatar
ctfuzzy
For starters, I'm talking about the 98-99 torsion bar 4x4 Rangers.
Has anyone out there installed the superlift suspension kit and ~then~ tweaked the torsion bars to get that extral little bit of lift like us cheapskates that don't do the lift - we just jack the bar adjusters?
Did it "work"? Are you breaking front driveshafts (or couplers)?
Here is my reason for asking; the holy grail. Yup - The Holy Grail; Ground Clearance.
Even my 1960's damaged brain noted that the 1~3 inches gained from that torsion bar twist is TRUE ground clearance; you don't have to put on bigger tires to clear higher rocks under the front crossmember.
Thus the logic follows, at least in my tiny mind, that this is a good thing if ground clearance is the goal . . . and physics will allow it.
<.Tangent>
It just gripes the devil out of me that I buy a "3-4 inch lift" when in fact I will only get half of that under my differentials - and that is only if I buy another dogone expensive set of tires TOO.
<./Tangent>
Oh, that subject line up there . . I have found myself at times quite annoyed at only being able to find a "3-4" lift" for my 98 Ranger. I have been looking for months and months for something bigger. Well, finally a couple of long dormant brain cells fired and I had a . . . . original thought. Here, check this out:
3" Body Lift + 3.5" Suspension lift + 2.5" torsion bar twist = 9" of total lift.
9" of lift on my daily driver - and I travel a LOT - is way the heck more than I would ever want. I'm a happier person now. . . . I just thought I would share that with you all .
. . TIA,
Mike.
Old Oct 5, 2003 | 08:15 PM
Peter94's Avatar
Peter94
hey, i have a question, I dont know much about the suspension, but is that torsion bar twist possible to do on 94 4x4 rangers? cause i'm looking for a cheap lift. and does it mess up your steering geometry, cause uneven wear on your tires, or make the truck shake at 60 mph or anything like that?
Old Oct 5, 2003 | 08:29 PM
ctfuzzy's Avatar
ctfuzzy
Peter,
I do not believe your truck has the torsion bars - sorry.
Mike.
Old Oct 5, 2003 | 08:49 PM
Rockledge's Avatar
Rockledge
Mike,
Cranking your torsion bars has ramifications that you have to consider carefully. There are the immediate effects such as throwing off your truck's alignment, and I also believe it can lead to suspension problems in the long run: Read Here
Old Oct 5, 2003 | 09:54 PM
ctfuzzy's Avatar
ctfuzzy
Wow. This is a much friendlier list :-).
I got to play a little in the woods this weekend for the first time since I tweaked my torsion bars. On more than one occasion the "slam" I heard sent shivers up my spine.
I may not be a mathmatical mastermind, but I have have broken enough parts in my life to know that ultimately that sound is destructive.
. . . great, now I'm going to look like a 4x4 funnycar coming down the road, because the rear end is sky high. Sometimes life just stinks.
Mike
<.looking for the lemonade pitcher>
BigTonyG
Sep 21, 2006 04:31 PM
smplfrk
Mar 16, 2005 12:50 AM
jdhudall
Feb 20, 2005 03:55 PM
old yeller
Aug 27, 2004 04:08 PM
98f250lightduty
Jun 9, 2003 12:10 AM
