97 f250 HD 5.8L tune up
Looking to do a tune up on my truck, rotor, cap plugs, wires. I've seen different opinions on what and what not to buy. Is the 9mm wires a good option or stick with factory? Might need to replace the distributor also, mine looks cruddy like it's been in saltwater and is different from other ones ive seen.
different how? Got a pic we can see to check it out? Curious what might have been installed and is old enough to look that bad.
On plug wires you can stick with factory, or go with Ford Racing wires, or probably several other brands too. I've heard of the occasional bad plug wire, but never had one yet myself (knock on wood and plastic and maybe some carbon-fiber for effect!). With the sad state of parts these days though, if you get Motorcraft branded stuff you at least have a better fighting chance.
How's it running now? Badly, or good enough and it's just time for a tune-up?
Paul
Paul
Tune up
Running rough, and burning alot of gas. I know it's not great on gas but I have 2 tanks and have almost gone through both with not alot of miles and lacking in power. If you stomp gas pedal it has that hesitation. Have to get pic of distributor. Just got truck back lastnight, guy repacked wheel bearings and replaced bushings in the I beam axle but still has roaring noise, I know that the tires make noise but this sounds different?
Tune up
Yes tape is on wire loom, guy I bought it from said he just did a tune up but obviously he didn't! What I dont understand is why I have a tfl module in Glove box and not the distributor it fits? I'm going to stay with motorcraft even though it is more expensive but worth it. Cant seem to find plug wires at auto parts stores here and pricey online. Still throws a code for egr not working properly, changed sensor on top but didn't help. Does have a new tp sensor ( not sure what brand? )
Tune up
That's the problem! I can look online, find the part, click on it and it says doesn't fir your vehicle. I go in the stores, explain what I have and 50% of the time I get the wrong part so now I try to take the part with me and match them. I don't care about the flashy look, I just want it to run properly.
