AC cuts out
Old Jun 25, 2019 | 03:24 PM
dcara's Avatar
dcara
AC cuts out
Turns on ok and runs for about 5 minutes then cool air fades out and stays gone until system is turned off for about 5 minutes. Then it will come on and provide cool air for another 5 minutes Lo side pressure looks good at about 47. Air gap on compressor measures about 35mils. No defrost leakage when 4 wd is engaged.
Old Jun 25, 2019 | 04:18 PM
FordTruckNoob's Avatar
FordTruckNoob
47psi on lo side seems a little high. That is idle I presume? Check hi side to see if it is excessively high. When cold air goes away, has the AC clutch disengaged?
Old Jun 25, 2019 | 08:46 PM
'88 E-350's Avatar
'88 E-350
From foggy memory, .035 is the high end of specs for the air gap. Is the clutch staying engaged when you loose the cold air?
Old Jun 25, 2019 | 09:32 PM
Wallace Mcelroy's Avatar
Wallace Mcelroy
I had something like that happenn to mine. It was to much freon oil in system causing it to cut out because of high pressure
Old Jun 25, 2019 | 09:40 PM
Shawn.54's Avatar
Shawn.54
My truck had weak or no ac and and it turned out to be the senser on high side that controls clutch. The wires that run into it were broken from being crushed while working on motor.
shawn
Old Jun 26, 2019 | 09:02 AM
dcara's Avatar
dcara
Thanks guys. I have been planning to pull over and check if compressor is running next time it cuts out but so far it hasn't been "convenient" to do and so it always been "i'll do it l;ater"
What should highside pressure be in case I need to check that.
Old Jun 26, 2019 | 10:12 AM
'88 E-350's Avatar
'88 E-350
https://www.google.com/search?q=r134...0ezyA_loLjm0M:
Old Jun 26, 2019 | 12:09 PM
FordTruckNoob
No more than 250psi or the high pressure switch will disengage the clutch.
Old Jun 26, 2019 | 01:20 PM
Finmanfish's Avatar
Finmanfish
That happened to mine. Took it to a guy who knew what to do. He pulled a shim out of the clutch on the compressor, problem solved. The man who did it was the owner of a reputable ac shop in Mobile, Al. He said he sees this allot.
Old Jul 1, 2019 | 09:44 PM
kbeefy's Avatar
kbeefy
47 is pretty high, what is ambient temp? And what is the high side? Figure out if the clutch is cycling.
My bet is low charge, but you need more info and a proper evac to confirm that.
Old Jul 2, 2019 | 05:17 AM
FordTruckNoob
That is a clutch air gap issue. That situation assumes refrigerant pressures are okay. One should always check refrigerant pressures first whwn troubleshooting AC issues.
If refrigerant pressures are indeed okay, one way to test if the air gap is marginal is to tap on the front of the clutch while the AC is running and see if the clutch engages. If it does engage after a tap, then removing that shim should fix it. If not, then the clutch solenoid is probably bad.
Old Jul 2, 2019 | 09:21 AM
dcara's Avatar
dcara
Clutch air gap issue fixed by removing washer behind clutch on retaining bolt. Blows cold all the time now.
Thanks everybody
Old Jul 2, 2019 | 09:29 AM
BillyBob69's Avatar
BillyBob69
Thanks everybody
So you had more than one and removed only 1 or there was just 1 there and now none?
Old Jul 2, 2019 | 09:54 AM
dcara's Avatar
dcara
Had only one and removed it so now there are none.
Old Jul 2, 2019 | 10:28 AM
BillyBob69's Avatar
BillyBob69
Hmmm Thats what i had on mine so I left it. Figured taking the last one out would be too close. Wound up just doing a little cleaning on mine to get it to work again.
