Dead battery after 2 years?
Old Jun 24, 2019 | 09:06 AM
clc3251's Avatar
clc3251
2017 F350 6.2. Battery quit on me after only 2 years. Is this a common problem? Wasn't happy to spend $200 on a battery on a 2 year old truck. Plus it was a good time to add the second battery that I set it up for. $400!
Old Jun 24, 2019 | 09:21 AM
Flyct's Avatar
Flyct
FTE Community Team
Battery is fully warranted by Ford for 3 yrs/ 36k miles.
Old Jun 24, 2019 | 10:02 AM
Tedster9's Avatar
Tedster9
Battery is sort of like a piggy bank, take out more than you put in it will be empty and die an early death. Check alternator output, and also for parasitic or phantom load.
Old Jun 24, 2019 | 10:05 AM
seventyseven250's Avatar
seventyseven250
Even a brand new battery can die in weeks if there's an issue causing it more stress. Parasitic drain is a common one.
Old Jun 24, 2019 | 10:22 AM
AZFordLover's Avatar
AZFordLover
Do you run it in extreme (very hot or very cold) climates?
Batteries in the Sonoran Desert live short, hard lives - 2 years is pretty much standard when air temps are over 100 every day for 3 months.
Underhood temps can easily be 120+, especially under load.
Old Jun 24, 2019 | 11:21 AM
Joe T's Avatar
Joe T
Lots of miles, idling, and hot and cold temps will shorten the life.
Battery quality has gone down in the last few years. I think it has something to do with lead not being as available.
Old Jun 24, 2019 | 01:36 PM
honda250xtitan's Avatar
honda250xtitan
2 years is pretty normal here in Arizona. also that should've been under warranty anyways. Got both of mine warrantied a couple months ago.
Old Jun 24, 2019 | 04:12 PM
Sagnasty's Avatar
Sagnasty
Everything to pinch a penny...that is why quality, such as batteries used by Ford are typically garbage. It is mind blowing at the price you pay for these trucks but unpsetting when the manufacture skimps on cheap parts that will leave you stranded. However, like others have said, cold and heat will zap a battery rather quickly depending on where you live. The best advice I have ever taken when it came to this topic was buying a quality AGM battery and never looking back. They are a night and day difference from your typical lead acid and will out last most everything else.
Old Jun 24, 2019 | 04:24 PM
TeddyD's Avatar
TeddyD
In my area, everyone I know that drives a Ford has to replace a battery around that 2yr mark. Lol most of those are F-150s though.
Old Jun 24, 2019 | 05:06 PM
ford390gashog's Avatar
ford390gashog
I got really tired of both my 17 and 18 leaking battery fluid. I swapped in the Odyssey Extreme batteries and they are easily 20lbs heavier than stock due to the pure lead. The price was a little ridiculous at 400.00 each so we will see if they hold up.
Old Jun 24, 2019 | 05:22 PM
blueiron's Avatar
blueiron
Only three companies make AGM [absorbed glass mat] auto batteries for the North American market. Heat and cold are battery killers, as are short commuter profile trips.
Old Jun 24, 2019 | 06:34 PM
Painted Horse's Avatar
Painted Horse
I plan on replacing Ford OEM batteries at 3 years. Doesn't seem to matter, Truck, wifes car or kids cars, OEM batteries around my house are dead 36-40 months
Old Jun 24, 2019 | 06:40 PM
Tedster9's Avatar
Tedster9
Heat. Batteries last a lot longer in northern states.
Old Jun 24, 2019 | 06:51 PM
2019er's Avatar
2019er
If you have 2 batteries, how to you tell when one or the other is about to die, or almost dead? Seems like the stronger battery would carry the other one up to some point.
Old Jun 24, 2019 | 07:01 PM
Jointasset's Avatar
Jointasset
It’s a motorcrft battery. I have them in my Excursion and then in the trucks(2012/2018). Usually die right before warranty runs out and they replace at no charge.
