Straight up timeing
Old Jun 22, 2019 | 11:45 AM
ss27gogeta's Avatar
ss27gogeta
Straight up timeing
I'm thinking about changing the timing set on my 78 f150 351m. To straight up timeing I've read I should get a timeing set for a 1970 351c. If I do this will my stock 2 barrel still be fine or am I going to need to get a 4 berrel. And how much power dose straight up timeing add.
Old Jun 22, 2019 | 11:59 AM
Dave145's Avatar
Dave145
The stock 2bbl will be fine. It doesn't really "add" much power as much as it makes the power you already have more useable. You may feel a slight difference from the drivers seat but that's it.
Old Jun 22, 2019 | 12:28 PM
hail destroyer's Avatar
hail destroyer
If it's got over 100 thousand on the odometer, probably should be changed anyway. Water pump while your in there.
I was amazed at the difference on even a beat to death, low compression and oil pressure super high mileage 351M when I installed a straight up timing set, added dual exhaust and a 4 barrel carb and intake. Not faster, but a noticeable increase in torque, better idle quality and more usable power throughout the entire RPM range.g it slightly better MPG, most likely due to the smaller primaries of the 4 barrel and the engine breathing more freely through duals. Of course, that wasn't enough, so I went back in 6 months later with a cheap, no name brand "RV" torque cam from eBay and that really made a difference. Lots of power,.....so much so, that I got a rod knock from beating it to death a year later. Still runs and I'm still driving it though, just can't kill these old 351M/400s.
Old Jun 22, 2019 | 12:44 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Old Jun 22, 2019 | 12:54 PM
ss27gogeta's Avatar
ss27gogeta
What cam did you put in it. I would like to put a cam in mine since I'll be there any way. but I don't have the extra cash now for an intake and carb. if put a cam in could I get away for a while useing my 2 barrel carb. and I'm assumeing I'll have to put new lifters and springs in. My engine has 118k on it with good oil pressure.
Hiltz390GT
23
Feb 9, 2017 05:16 AM
hail destroyer
Apr 22, 2016 10:21 AM
79_effie
Feb 24, 2012 07:04 PM
yamahafella03
Feb 7, 2009 11:25 AM
77ford guy
May 10, 2006 05:20 PM
