Payload rating for towing - Thought experiment
In mind as I say this: Almost nobody gets to the theoretical "full" mark in these. They are a few hundred pounds below or above, but never right on it. The ones that are below will have a hundred pounds more truck to influence the trailer. The ones that are above probably don't notice that they have a hundred pounds more truck to influence the trailer.
Either way, the base truck is X pounds and the optioned truck is X+~100 pounds so not a huge difference anyways. An 8,000-pound XLT CC LB is probably 8,100 pounds when it turns into a Lariat so we're talking 1.25% weight increase. In the F150 range it would be more like a 5,200 pound versus a 5,400 pound CC LB so 3.8% difference. Both seem like negligible differences that most drivers wouldn't notice.
That having been said, when I emergency-stop 1" from whatever I almost hit, I'm going to think "glad this thing didn't weigh any less than it did, that extra traction probably saved me" . . . then . . . "I wonder if it would have had 2" to spare if it had weighed a bit less?"
Received 7,149 Likes
on
400 lbs does seem a bit much. If I had known it was 400 lbs and leaving it off the build of a Lariat Ultimate was an option (it wasn't in 2017), then yes, I probably would have.
As the name implies the heavy duty payload package is to maximize the GVWR of the truck and the Max tow package is to maximize the GCWR/ TWR of the truck.
HTH,
Jim / crewzer
Hmm, the 400 didn't sound right, but that 64 lbs sounds suspiciously low too. Oh well, I guess a) there's no simple way for me to test this and b) it doesn't really matter.
Now I'm not saying anyone should be towing at 100% max of any trucks trailer ratings. I sure wouldn't. But it's an interesting discussion.
I know it isn't 400, that wold bring my lariat to almost 2000lb payload capacity, which would be nice!!
That makes sense, but for most people using a half-ton truck, there's no way to reach maximum trailer weight without exceeding payload rating. Family of 4 plus a little gear in the bed is easily 800lbs, plus tongue weight of a 12,000lbs trailer (13%) = 1560 lbs = 2360lbs payload, which is higher than the payload rating of the max tow NON HDPP supercrew trucks.
And many people who tow without four people and and gear in the bed, sure that's that's true as well. I agree. Although, I think for the "average" half ton buyer, most of them are towing travel trailers and bringing family with them.
Payload rating aside, manufacturers should provide some type of guideline to derate maximum tongue weight and TWR based on the less than ideal 10% tongue weight. Example for every 1% of tongue weight above 10% reduce maximum tongue weight rating by 100lbs which will reduce maximum trailer weight as well. Let’s say the 10% rating on a truck is 1200/12,000 the 13% rating would be 900/6925.
#28
#29
carolinaborn82
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
22
08-08-2012 01:50 PM
