First Econoline; '87 and an engine swap
Hello! This is my first post, my first van, and my first massive project. I've always been a van guy; grew up with various vans as a kid. Nothing too funky, just old 80s and mid-90s ones that always died within a few years... I'm 27 now and with my first car (1990 Buick wagon) having just died the death of Salt I was in search of a BETTER station wagon (I need lots of covered space all the time). I found a 1987 cargo 150 which had lived its entire life in the California desert save for the last couple years. Was owned by a guy who had a wheelchair lift put in it and never drove it much but also never changed the oil...
Prepare yourself for way too much information. But this is what I got:
I can go on for another 3 paragraphs but I'll start with that.
So, hello! Hi! Give me all the information you can towards this project. Things I should do now. Things I should do later. Things I should avoid. Brands I should avoid. I'm poor but I'm dedicated to "doing it correctly". I don't care about 30 dollars vs. 60 dollars. 150 vs. 320 is a bit tougher.... And I DO have a parts-request list started.
Lovely to be here,
Ian
- Has a 302 in it (EFI). Bad rings. Especially bad cylinder 2 (wet plug vs others being dry). Has AOD and a sliding door. Glass on the doors, nothing on panels. AC unit but I believe the lines have rotted away.
- Not a lick of rust on this van at all. The belly of the body is still painted; couple of rusty dots where a rock hit it or a hole was drilled for the wheelchair crap. The frame effectively just has surface rust. You can wipe it off with your hand. The last two or three feet of the underside is covered in ancient oil from the rear diff I believe having a malfunction at some point (there's a service sticker on the van).
- The oil smoking thing is mildly out of control. The crankcase breather tube thingy that goes into the air cleaner doesn't really seat and usually blows lots of smoke when you step on it and a fair amount of oil also comes out of it. When I first opened up the cleaner the filter was saturated. Now the tube is off but I believe it still comes out occasionally. I changed the oil with some very heavy Rotella T6 and it seems to have actually helped a bit. It still smokes but not as badly and mostly just when you stomp on the gas.
- First and second gear seem fine, maybe a bit lumpy in first if you're on a hill, but don't usually notice it. The van naturally kicks into 3rd gear at 20 mph. If your foot is on the gas and you're not going down hill--serious shakes. Take your foot off (or very little gas), going downhill, or hit about 30 mph it smooths out. Stomp on the gas and the transmission reacts very quickly, downshifts, and everything is peachy-keen. Let go at 30+ and it's fine. Overdrive does the same thing (I usually leave it in drive unless I'm going 45-ish (which I avoid if I can)). I am assuming this is the misfiring in cylinder 2 causing a bad unbalancing at low RPMs and high load. Unless someone knows otherwise.
Lovely to be here,
Ian
Great Idea
I have the Same idea!
I was looking while at a junkyard,today.
my idea is to Look for a E or F series
'87- '91, for parts,
to make an E with 6 cylinder.
(I did see an '86 today 5.0 fuel injected)
I don't know how Different
Truck engine wiring harness
is from Van engine wiring harness,
it can be made to Fit
since truck should have Longer wires
than the vans.
Van would be easier.
There are not many wires
that go to that Engine,
from memory:
Starter solenoid
Alternator
water temp
oil pressure
Distributor from Electronic Ignition box
coil
as I think about it
the 5.0 should have the Same wires
they may be Long enough,
just add wire length where it's needed.
Be sure the wire diameter/wire gauge
is the Same or larger diameter.
you could uses wire
of the same Color combination
and same diameter
from another truck or car
of any make or year.
(just to make troubleshooting easier)
6 cyl Frame mounts may be different
than 5.0 frame mounts.
frame mounts attach to frame,
motor mounts go between frame and engine.
any other Questions?
BTW
Good generation choice,
Probably the BEST.
than the vans.
from memory:
Starter solenoid
Alternator
water temp
oil pressure
coil
as I think about it
you could uses wire
and same diameter
BTW
Probably the BEST.
Wow----not to even slightly discourage either of your enthusiasm but you're both facing a lot of work---I do have to ask with respect what's the goal? Will the resulting van(s) be a daily driver with huge reliability or are these projects you'd like to tackle "just because....." , something to do just for the sake of doing it?
Do either of you have the time, money, space, tools and experience how to accomplish all this? If you're looking for a daily driver are there no other choices in your local areas, something dependable and not too costly, something that doesn't need such huge conversions?
Lots of work and plenty of challenges ahead---hope you're prepared for what lies ahead.
Men Love Challenges
Men love Challenges.
This will be a Useful project.
True enough---Don Quixote comes immediately to mind though. I love a challenge but it has to come with a pay off far, far beyond doing something---IOW I have to produce something practical and useful.
Which brings me to ask HOW would this be a useful project?
annaleigh
24
03-18-2018 09:34 PM
FLAKwagon
02-28-2016 12:32 PM
shark13
07-28-2015 12:05 AM
cyborger
02-26-2015 10:49 AM
