Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
2013 Ford Edge A/C problem
Old Jun 15, 2019 | 06:11 PM
fatpadre's Avatar
fatpadre
A/C high pressure goes to 450 psi at stop signs and shuts off compressor until pressure bleeds down to 340 psi. It works okay while rolling.
Old Jul 3, 2019 | 09:43 AM
fatpadre's Avatar
fatpadre
My apologies and thanks to m-chan68 in another thread. I'm just an amateur on A/C systems and this is my first A/C unit with electric blowers. I didn't realize the high pressure could go so high if there was no cooling. The cooling fans weren't working and I found a burned contact in the fan connector that plugs onto the fan control module. The fans worked with 12VDC applied directly to the connector and the control module had 12 VDC on the output pin but the two wouldn't make contact when plugged together. Now do I have to buy a complete new fan assembly or can I get a replacement connector somewhere? Any help is appreciated.
Overcast451
Escape & Escape Hybrid
Mar 7, 2022 07:38 PM
gpeade
Oct 31, 2019 11:30 AM
fatpadre
Crossovers
Jul 3, 2019 07:26 PM
Rusty_S
Jun 26, 2019 08:51 PM
jtharvey
Aug 4, 2008 09:50 AM
