My issue is that the reverse lights do not light up in reverse. They DO WORK when you turn off the car ( the white lights at the back of the cab). My mechanic checked the fuses and said it is likely a costly transmission module.
Anyone have input on this? If it is the module, can someone tell me what this part is called or item #?
bump - based on my research, if the transmission module were bad, my transmission would not work at all. Does my truck have some sort of light switch near the shifter?
