Track bar clearance
Old Jun 13, 2019 | 02:28 PM
devovino's Avatar
devovino
Track bar clearance
Finally getting around to installing new pro comp front leafs, po owner had drop track bar bracket that is interfering with drop pitman arm. Recommendation for finding a stock/correct track bracket. Thanks in advance
Old Jun 13, 2019 | 02:35 PM
EXSwap's Avatar
EXSwap
If you're looking for OEM, I found this one. Fairly expensive for my taste. I'd bee hunting scrap yards. Not sure if other (F-250/350) brackets will work.
https://www.tascaparts.com/oem-parts...iABEgJkVvD_BwE
@pirate4x4_camo may have a better source for aftermarket parts
Old Jun 13, 2019 | 03:29 PM
devovino's Avatar
devovino
Yeah a little rich for my blood, I already have a call into brads auto.
Yeah maybe pirate has an idea. He can also let me know what he thinks about these shocks.
1999-2004 Ford Superduty Bilstein 5160 Series
Old Jun 13, 2019 | 03:34 PM
devovino's Avatar
devovino
I just saw this on pmf site, of course my luck they are not in stock...
1999.5-2004 F-250/350, Excursion Replacement OEM Trackbar Mount
Old Jun 13, 2019 | 03:45 PM
pirate4x4_camo's Avatar
pirate4x4_camo
That is a replacement for the axle side
Old Jun 13, 2019 | 04:31 PM
devovino's Avatar
devovino
Right, found that out after talking to pmf,back to drawing board.
Old Jun 13, 2019 | 07:06 PM
devovino's Avatar
devovino
So any recommendations on a track far mount that works with drop pitman arm?
Old Jun 13, 2019 | 09:13 PM
pirate4x4_camo
Depends on how much drop your pitman arm is.
the track bar and pitman arm must have the same drop. Use a 4” drop pitman you need a 4” drop track bar mount.
Old Jun 14, 2019 | 09:06 AM
SmackDaddy's Avatar
SmackDaddy
Basically what pirate is saying is keep the track bar and drag link parallel or as close to parallel as possible.
Old Jun 14, 2019 | 12:54 PM
devovino's Avatar
devovino
Right, well to be honest the previous owner seems to have put on a 4in drop track bar bracket, with the 4in lift that was put on previous to me, and I put on a 4in drop pitman arm and it’s interfering with each other.... so now what..? Call pro comp?
Old Jun 14, 2019 | 03:08 PM
pirate4x4_camo
you can try calling but since they cant see what is interfering any better then i can my guess they will want to sell you matching parts since it seems likely you dont have what you think you have.
a 4” excursion lift does not require a drop Pitman/ track setup just an adjustable track bar.
Old Jun 14, 2019 | 03:42 PM
devovino's Avatar
devovino
Copy that, yeah honestly I don’t know exactly what was put on by the previous owner. What I do know is the front leaf springs were superlift as they had a sticker on them, equating to 4 in lift in the front. As for the track bar setup, it appears to be a “stock” or non-adjustable track bar there now attached to a drop track bar mount. There was never a drop pitman arm on until I put the 4in one on with the new pro comp 6in lift leaf springs, that is interfering with whatever drop track bar mount was already in place.
Also, pirate while I have your attention, do you think there is any need to get those bilstein I linked above from PMFwith remote reservoir vs just a regular bilstein shock w/o reservoir, I dont do a whole lot of off roading, but hear they handle much better in off-road situations. Your the man! Thanks
Old Jun 14, 2019 | 09:46 PM
pirate4x4_camo
Ok my bad, I though you had 4” of lift over stock ride height.
with more then 4” of lift you would need to use a dropped pitman which of course would mean you need to also drop the track bar to keep the drag link and track bar parallel.
Shock, I have no experience with that model so can’t speak to them, you can go to the Bilstein catalog and compare the compression and rebound valving to the ones I frequently mention. If the valving is the same then they will have the same ride characteristics. The addition of the remote reservoir doesn’t change the ride it allows you to beat on them longer off road without shock fade. If you don’t off road your Ex then the reservoir is of no benefit.
If the valving is different that doesn’t mean they are bad, just different, for all I know the valving May be more suitable as the 5100 are not perfect, just close enough for most people on the street and light dirt road driving,
Old Jun 14, 2019 | 09:59 PM
devovino's Avatar
devovino
Gotcha, yeah I have been looking for just a standard/stock track bar mount as that should clear the drop pitman arm without issues. You mention using a drop bracket for the track bar, do you know of any that will also clear a 4in drop pitman arm? It seems it’s critical to keep the trac and drag link parallel so I need to find the correct drop trac bar bracket. have not yet but would it be ok to drive without the trac bar?
Old Jun 14, 2019 | 10:16 PM
pirate4x4_camo
If you use a stock track bar mount with a dropped pitman arm then you will get bump steer. So do not do that.
If you have a 6” lift then you need a dropped pitman arm or your TRE is going to bind at full droop. You need to use a dropped track bar mount that matches the pitman arm you installed.
