Need some info - pulley problems
Old Jun 12, 2019 | 10:14 AM
Redrokin09's Avatar
Redrokin09
Can anyone tell me what this pulley is referenced as? and or part number for it? It
has the wobbles.
I ordered a high glow water pump from FlowKooler. While I have everything taken apart, I just as well replace some stuff. I did order drive belt pulley by the A/C. This one is directly under the A/C.
Old Jun 12, 2019 | 10:28 AM
440 sixpack's Avatar
440 sixpack
It's called the A/C fixed idler. if it's on an FE they are no longer available anywhere I've been looking. there are used ones on ebay.
I'm told there is a way to put new bearings in one but since I don't have one yet I'm not sure what bearings or how it's done.
Old Jun 12, 2019 | 10:36 AM
Redrokin09's Avatar
Redrokin09
That's a huge bummer, well... I'll take a look at this weekend and I'll post some close up pictures. I'd be tempted to put puller on it, but I don't want to break it.
Old Jun 12, 2019 | 10:39 AM
Redrokin09's Avatar
Redrokin09
Thanks for the info BTW
Old Jun 12, 2019 | 10:55 AM
Redrokin09's Avatar
Redrokin09
So, I just came across a post that refreenced that as this part # D0AZ-8678-B
After doing some searching, it lead me to this part. https://secure.cougarpartscatalog.com/c5zz-2990-a.html
this weekend I am going to take closer look at it to see if this would work.
Old Jun 12, 2019 | 11:44 AM
440 sixpack
That looks like the right one. thanks for finding it.
You can get by without it if you run your belt as tight as a fiddle string. but you'll still get a little belt slap when the compressor is running. putting a new bearing in would be worth your while.
Old Jun 12, 2019 | 12:07 PM
Redrokin09's Avatar
Redrokin09
I completely agree, I have no idea if this is the correct part or not... only one way to find out. When I pull it out this weekend i will closely inspect it
Old Jun 12, 2019 | 08:43 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
This is not an idler pulley, it's the A/C's compressor clutch and pulley assembly (2891 in pic). The field (2987) is a separate part, a bit of it can be seen in the background.
The clutch has a bearing inside that is replaceable.
What the hell??!! D0AZ-8678-B idler pulley does not look anything like this! The pulley itself is much smaller and it bolts to the compressors support bracket.
Pic: See 8678, 2891, 2987.
Old Jun 12, 2019 | 08:48 PM
440 sixpack
I think it' the idler under the compressor he's looking for.
Old Jun 12, 2019 | 08:56 PM
Redrokin09's Avatar
Redrokin09
This isn't my first truck. Look closer, the one with the big blue circle around it in the picture. Below the A/C clutch..... get your glasses on.... I'll wait
Old Jun 12, 2019 | 09:03 PM
NumberDummy
That may be, but the OP circled the compressor clutch, in the background you can see a bit of an idler pulley.
Look at the parts catalog pic. Notice the right & left idler pulleys.
Plus, D0AZ-8678-B is a fixed idler pulley for a Passenger Car w/a 429/460 or 1973/79 F100/350 460.
360/390 is different and there's a right and left.
Old Jun 13, 2019 | 08:48 AM
DB429SCJ's Avatar
DB429SCJ
What engine? Looks like a 429/460.
Old Jun 13, 2019 | 08:58 AM
Redrokin09's Avatar
Redrokin09
460, should have mentioned that from the beginning.
strokinout
Apr 4, 2016 10:19 AM
Cody_1948
15
Mar 21, 2014 07:38 PM
38 coupe
Jul 8, 2011 09:12 AM
Orange '63
Jul 21, 2009 08:30 PM
coores14
Apr 29, 2009 04:08 PM
